Flatie
2:24 AM
The Island
Also noticed this oily residue/carbon coming out of the decomp plug....is that normal or is it leaking? It's never used for starting.
Flatie
2:24 AM
The Island
That's not horrible for the 800. I would check the decomp to see if it's tight or just block it off if it is leaking.
Would you say that's leaking from the pic? I would of thought there shouldn't be any spoogy mess coming out from what looks like the centre of the plug. Any of your saw plugs look like that?
Benelli777
9:24 AM
Québec , Canada
Again not to derail the thread again but does anyone know what oil they put un the Truefuel 50:1. My father only uses that stuff in is 336FR brushcutter
I tought I read somewhere here or on Another Forum that it was Motul 800T.
I can tell you guys that Irun Motul 710 (40:1) in all my saws now and the smell is nowhere close to 710. Put 6 thanks in my 562 and 545 this morning and after lunch I am using the brushcutter. What a pleasant smell
Thanks
JF
9:24 AM
Thanks
JF
It's not motul in that one. I don't know if they've ever really said. I prefer the 40:1 trufuel for canned fuel.
Benelli777
9:24 AM
Québec , Canada
Ok newbie question. Does the 336FR carb will adjust ok or will Ineed to adjust (if it is an adjustable carb that is)
And yes I agree with you. I run 40:1 in my OPE. My father is still cursed by the big company's BS
bwalker
9:24 AM
Montana
Plug out of my 550xp only ever run 800 @ 40:1.... Looks kinda dirty to me. Thoughts? Also the piston seems to have a fair bit of carbon on it considering not a huge amount of run time.
Nothing stand out in those plugs. The wetness is probaly from idling or low load prior to shut down.
With that said I have never been impressed with 800, but especially in a saw. It just doesn't combust well at load appropriate to normal saw usage.
KenJax Tree
¯\_(ツ)_/¯
9:24 AM
Over there
Went riding for a little bit today. Got to the gas station and asked my buddy where he put my oil, "on the bumper, I though you grabbed it before we left". Well, i didn't grab it so there is a bottle of golden spectro out there somewhere.
I ended up mixing Amsoil Dominator 50/50 with Klotz R50 (didn't have enough to use one or the other) to mix 2.5 gallons and it ran pretty damn good.
smokey7
9:24 AM
Detroit
I have never used dominator, the warnings about rust always scared me off it. I'm sure it's great oil tho. Klotz is a oil I don't think I have ever ran maybe I should try it.
KenJax Tree
¯\_(ツ)_/¯
9:24 AM
Over there
I've read about the rust on MX forums but have never seen it personally.
I could see in a boat or snowmobile it makes sense if there isn't rust inhibitors but not sure how a dirt bike under normal conditions would get moisture in it.
The guys i've known to use it have never had a problem. YMMV i guess.
Magnumitis
Kevin in Arkansas
8:24 AM
yes
Atmospheric humidity
And the whole warming and cooling thing usually causes condensation
bwalker
9:24 AM
Montana
Many dirt bike cranks show evidence of corrosion. And ester oils in general are pretty poor at preventing rust.
