Keith Gandy
Maxima K2 40:1 87 Pump Gas
- 6:04 PM
- Dec 30, 2015
- Provencal, Louisiana
Wouldnt suprise me if it was the same oil
I have not tried it in my saws ,i did not have any good mix at work and used what i found it in a junk car here ,i was amazed it ran real good with it .Wouldnt suprise me if it was the same oil
Ive ran a good bit of lucas in ported dirtbikes at 32to1 with no issuesI have not tried it in my saws ,i did not have any good mix at work and used what i found it in a junk car here ,i was amazed it ran real good with it .
I feel the same way ,a lot of my outdoor power equipment runs better with the stuff made for it ,hmmmI think most of the oils we r discussing and using r overkill
I have torn down some logger hand me down saws that bearings looked sooty like that ,if they would go 40 to 1 i think the soot would be less and wash better ,50 to 1 seems a tad too dryIve seen quite a few saws in the shop ran on convenient store oils that looked fine. Stihl oil carbons up as bad as any ive seen
QTLA5TIMESI think most of the oils we r discussing and using r overkill
My jred 625 bearings looked like that too. TCW3 for 20 years. They were still good thoughI have torn down some logger hand me down saws that bearings looked sooty like that ,if they would go 40 to 1 i think the soot would be less and wash better ,50 to 1 seems a tad too dry
I have seen some cheaper oils used in stuff brought in the shop that carboned everything from the bottom transfers on out! Tune may have had alot to do with it though?QTLA5TIMES
Magical conglomeration of crap that carbons!!! Lol!!stihl ultra is a magical thing.
Man u got that post count poppin GOAT!!!stihl ultra is a magical thing.
The GOATbot is running smoothly.Man u got that post count poppin GOAT!!!
Could have. Not sure. Isn't the stihl ultra fb rated? Or it used to be. That might be why also. Less detergents. Everybody says it's some dirty stuffI have seen some cheaper oils used in stuff brought in the shop that carboned everything from the bottom transfers on out! Tune may have had alot to do with it though?
I saw that. Mike I think it was a salesman saying it would and Amsoil would warrantyDiscussion on facebook saying saber @100:1 will last milling. I'm not so sure. I seen the westspartan's 441 with that stuff and it was dry and brown burnt on the underside.
