11:14 AM
Yes...
Can you run a test with no oil in one of your Dollies for us?
Nah, that'd be sacrilege!
They're angels and goddesses of chainsaws. :worship2:
But any Stihl will do, they're a dime a dozen and I got no boat anyway.
I'd record it too. :D
Them Hooskies have a built in safety feature, they fall apart before they manage to seize. :p
You into no lube:confused:
More friction, watch Crank 1 & 2. :rolleyes:
11:14 AM
SOS Ridgerider
Muffler Modded Member
5:14 AM
Central CT
ammoaddict
5:14 AM
Granite Falls, NC
BM200 test over at 9 hours and 6 minutes. The air filter in place reduced fuel consumption by a full quart plus a full trimmer tank. So it blew almost a quart into the air during BM100 without one. Good to know.
Anyway, temps just b4 shut down as well as the vid. Still 55°. Never moved off 55 all damn day.
1) crank case
2) cylinder
Teardown tomorrow.
View attachment 241475 View attachment 241476
Man, 55 degrees all day. I would love that. It got up to 85 here. I hate hot weather. It makes my head leak.
Sent from my moto g(7) power using Tapatalk
Moparmyway
Its just a saw
5:14 AM
In a meeting
Deal Of The Day Echo 2-stroke oil clearance
https://www.hlsproparts.com/product-p/6450025.htm
https://www.hlsproparts.com/product-p/6450002.htm
https://www.hlsproparts.com/product-p/6450001.htm
No idea whether the price is right, I just thought someone might be interested.
I've used a good amount of Powerblend, and it's done just fine. Wouldn't hesitate using it again.
Its FD rated
I used that stuff @ 32:1 for years .............. before I learned that there was "forum oils"
No failures of any kind to report
Keith Gandy
Maxima K2 40:1 87 Pump Gas
4:14 AM
Provencal, Louisiana
Amazingly it still has excellent compression.
I ran 10-11 gallons of this oil @36:1 in my echo leaf blower from new. Piston wet, no build up on the sides. Thin layer of soft carbon in the exhaust port. No pics so guess you can take it as you wish.
Ill take carbon on top of the piston anyday over carbon in the ring land. If it keeps building there it will lay that piston and cylinder down
Keith Gandy
4:14 AM
After it surpasses 800 and Saber....a full mineral oil no less.
That very informative article posted here the other day that was done by a cycle mag that showed more power with more oil also showed much less carbon on everything except the plug with more oil.
Im in 100% ! More oil less carbon but need a dyno to justify more oil equals ring seal plus more power or less oil with complete combustion equals more power?
RalphK
2:14 AM
Left Coast
I read that article many years ago and have always subscribe to that philosopy in my karting days, flying RC, and any other 2 cycle engine.
