Keith Gandy
Maxima K2 40:1 87 Pump Gas
- 10:33 AM
- Dec 30, 2015
- Provencal, Louisiana
Walmart Supertech oil seems to be good oil but smokes a good bit just as Lucas does
I'm gunna use muh Lucas for portin lube ................ or assembly lubeWalmart Supertech oil seems to be good oil but smokes a good bit just as Lucas does
I did run the rest of my Lucas but it was probably like 16 to 1. Again I won't blame the oil but I had my first total failure using it. DryI'm gunna use muh Lucas for portin lube ................ or assembly lube
Better than throwin it away
Did it fail at 16:1 ?I did run the rest of my Lucas but it was probably like 16 to 1. Again I won't blame the oil but I had my first total failure using it. Dry
Nah 32:Did it fail at 16:1 ?
I ran about 8 gallons of supertechniplste through a Husky blower with no issues this summer. Fwiw.Ive used about every oil now and hadnt had a problem with any except supertechniplate.
What issues did you have with Super Techniplate Keith?Ive used about every oil now and hadnt had a problem with any except supertechniplate.
Immediately carbon my rings stuck on a 550xp within a few tanksWhat issues did you have with Super Techniplate Keith?
I have used it. I like it.
Did u use techniplate or supertechniplate? Big differenceWow. I am surprised.
Did you remember to put gas with it?[emoji12] [emoji23]Only thing I ran the super in was the 550 and it almost ruined the saw with buildup in the ringlands in a few tanks
Shoot man I dont know what was goin on with it but that Super is known to make a mess. Only way I caught the stuck ring was inspection through exhaust port and noticed blowby and tore it down and thats what I foundDid you remember to put gas with it?[emoji12] [emoji23]
I'm just poking at you. I'm not a dirt bike guy and have never run any of those oils except like a pint of Bel Ray that I mixed at 32:1 a few years ago.Shoot man I dont know what was goin on with it but that Super is known to make a mess. Only way I caught the stuck ring was inspection through exhaust port and noticed blowby and tore it down and thats what I found
Mix.8 gallons of oil or 8 gallons of mix? Haha
