Keith Gandy
Maxima K2 40:1 87 Pump Gas
11:48 AM
Provencal, Louisiana
How much do you mix with a gal. That's some good stuff for 4strokes. Haven't thought about it in saw or even 4 mix fuel.
I add 1 capful per gallon but since I started using Red Armor I havent needed it in my saws or yard equipment. I still use it in my truck and lawnmower
KenJax Tree
¯\_(ツ)_/¯
12:48 PM
Over there
For what its worth I run opti2 at 50:1 , not there recommend rate at 70:1. Have been running it for 10+yrs, no oil related issues.
Wont know how long they will run on that cause they burnt in the shop fire[emoji22]
Sent from Hoskvarna hills
Its ok to just blame the oil
mikey517
12:48 PM
Highland Lakes, New Jersey
I see no one but me likes husqvarna xp.
Hey that rymes.
Hey that rymes.
I use it, and the Low Smoke, too. Since reading this thread, I've tried several different saw oils. I like the Husqvarna XP, and Low Smoke. I'm actually leaning to using either all the time.
danimal
11:48 AM
Armpit of da Midwest
Presently I'm running amzoil dominator, designed for hi revving off-road race bikes. 32-1 is my go to mix. 40yrs ago 30wt motor oil was used, old saws labeled at 16-1.
Then fancy 2 stroke oils came out,,32-1 was the norm,, recommended ratio by manufacturers.. Then EPA stepped in,40-1 then 50-1 today is the standard.. I'll stick to 32-1 thank you, finally found an oil that doesn't leave built-up deposits from running rich..
Saber supposedly can be run at 100-1.... Not by me tho
jake wells
no longer here
11:48 AM
ky
i like husq xp oil but not the price powerblend is half the price around here
i mix 6.4 oz bottle of it to 1.6 gallon.
Keith Gandy
11:48 AM
Just the opposite if u run rich IMO. U wont make carbon and wash the piston instead of burning the oil and producing carbon
