bwalker
3:17 PM
Montana
I'm sure they are.
What oil company do you work for?
You want to use straight castor, go ahead. It's a really crappy choice for a saw and most anything else.
jmssaws
Banneded
2:17 PM
stihl saws
You can always justify another saw.
3:17 PM
Virginia
I'll agree with you for the ope, but my bikes and quads have lived well on 927 for many years.
CR500
3:17 PM
Western NY
This is the pic I sent my wife at work the day "beloved" arrived. She responded if it was still there when she got home she was going to use it on me. I told her if she could start it have at it.....
had a chance at it one time..... was hard to say no but I did lol....
now I'm looking at potential blown up 064s
Figure one of those will look good in my collection. Wonder If I could build one reasonably with after market crank cases and an original handle?
bwalker
3:17 PM
Montana
trying out some evinrude johnson 2 stroke premium oil in it smokes like hell at 50:1 though
Two cycle lawnmower engines really need a tcw3 oil and the owners manuals, at least for my lawnboy specs such. They are run at low loading, constant rpm. Running low ash OPE leads to fouled plugs and mettalic deposits galore.
bwalker
3:17 PM
Montana
927 isn't straight castor, Benol is. And even 927 is not optimal for most applications, bikes included. As mentioned I will run a castor blend like 927 in my bikes, bug only when dunking where high load and full throttle continuously are in the mix. For MX or trail riding your hurting , not helping by running a castor blend. In a saw there is zero benifits to running a castor blend let alone straight castor. And to the contrary there are many bad properties of Castors and castor blends.
jake wells
no longer here
2:17 PM
ky
Two cycle lawnmower engines really need a tcw3 oil and the owners manuals, at least for my lawn boy specs such. They are run at low loading, constant rpm. Running low ash OPE leads to fouled plugs and metallic deposits galore.
i run ashless oils in my lawn boys and my one toro. supertech outboard in the 1 gallon jug is what i usually buy and it doesn't smoke like evinrude/johnson oil
jmssaws
Banneded
2:17 PM
Royal purple says it's ashless. If I'm smart enough to read it properly.
bwalker
3:17 PM
Montana
I really like penzoil full synthetic in my LB, and I'm not a big penzoil fan
jake wells
no longer here
2:17 PM
ky
that oil is 17.99 here per quart is the only reason i have not tried it i hope you got it cheaper than me lol.
bwalker
3:17 PM
Montana
The other thing with LB'S is the are extremely sensitive to big end rod failures as the have a roller bearing over a shell bearing setup. I wouldn't dare run less than 32:1 if you have the RPM turned up like most guys do.
bwalker
3:17 PM
Montana
Ashless oils are marine oils.. if it says it can be run in a boat AND other equipment it's a marine oil.
jake wells
no longer here
2:17 PM
ky
i run 32:1 in my lawnboy it is a D600 engine and it only turns 3100 rpms set on the normal speed setting.
