Keith Gandy
Maxima K2 40:1 87 Pump Gas
- 5:27 PM
- Dec 30, 2015
- Provencal, Louisiana
Now we r talkin!! Like u said the other day it takes heat to produce energy and make power. If the top is sopping wet and clean its simple. U r putting the fire out so to speak and performance and combustion is incompleteYou guys realize 32 to 1 is leaner than 40 or 50 to 1 right ? So more oil could be hurting things on the top end. Gas is cooler than oil if you run it over your finger so the saw piston will run cooler at 50 to 1 than 32 to 1 . Yes your bearings are happy at 32 to 1 ,but is your piston ??
