jake wells
no longer here
1:14 PM
ky
i burn 40:1 or 32:1 depending on my mood but i use good oil
i got some motul 800 laying around and a little bit of belray si7
currently trying to burn up my stash of husky xp oil.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
1:14 PM
Provencal, Louisiana
try 25:1 for 10 tanks and report back.
Its a mtronics saw. 25to1 is alota oil for it and hp2 is a high viscosity oil not to mention this saw is strato gutted and pullin a good bit of fuel already. I was actually considering what Randy said about using a thinner oil like r2 @ 32to1
mdavlee
Hillbilly grinder
2:14 PM
TN
Just shows a bigger wash on that side. Piston top is wet too. Might not be able to burn the oil in that saw.
Keith Gandy
1:14 PM
Ya I took the bellzona out and raised the transfers to 118. Gained rpm in cut and ran very good but still loads on a long idle. I think its suckin alota fuel in
Keith Gandy
1:14 PM
Im thinkin of tryin a new manifold that the baffle is still intact and see what difference that may make?
mdavlee
Hillbilly grinder
2:14 PM
TN
Could help it some to direct the charge better.
Terry Hennessy
1:14 PM
Memphis, TN
Clogged screeeeeeen... perzactly or exactly; I have seen a piston ring lock down with a layer of carbon as thin as a magic-marker mark; I want a clean burn, not a carboned piston top/ fouled spark plug/ muffler dripping/ screen clog... just saying. The right mix works, the wrong mix creates new problems
