Terry Hennessy
- 8:01 PM
- Dec 24, 2015
- Memphis, TN
A thought to CONSIDER: despite the "leaner" EPA argument, an engine needs a certain amount to run right; too little= lean, too much = rich, and LEANER= HOTTER= too hot risk. Hotter risks changing oil from a lube into a goo, or glue. But blowing unburned gas or oil out an exhaust is not efficient, and is detrimental, usually fouled plug or carbon buildup on piston/ ring w/ cyl/spark screen damage.50:1 in these new stratos that use way less fuel is getting way less oil. The 550 didn't like motul 800 at 32:1. It wasn't getting hot enough to burn it. Still had spooge coming out of the muffler outlet. Maxima K2 ran clean in it at 32:1.
-In the 32:1 VS 50:1 discussion, 32:1/ 40:1 is actually leaner (on fuel) than 50:1; stated another way, in one ounce of fuel, 40:1 has 25% more oil than 50:1, (i.e. but only (0.004)= 4/10 of 1% less fuel (0.6 oz oil delta over 128-oz gas). Oil technology is not the same with synthetic as old 2-cycle petro based (w/ special additives) much less older days (1920-1960s?) where they used regular motor oil in a 2-cycle mix. It is the additives in the (petro) oil, and/or the new synthetics that make today's technolgy so much different. Keep in mind also that gas has a cooling effect and also a minor lube effect.
