- 11:34 AM
- Jan 28, 2016
- Dike, Iowa
I have also been working in the shop trying to get parts & supplies put away to create some additional space to work.
Mark
I had wondered what the stack of steel lamination was on the 611 carb. So it's the air filter?
Would you happen to have an extra stacked air filter?I had wondered what the stack of steel lamination was on the 611 carb. So it's the air filter?
The set up in this pic is not complete. There should be (2) “L” shaped brackets used to support the rear of the filter. From the bottom of the two rear nuts of the filter to the two screws used to hold the on/off switch. It’s pretty important too. The two studs used to hold the carb (and everything attached to it) are screwed into a plastic adapter that is attached to the cylinder with (3) screws. The carb is not attached directly to the cylinder and the plastic adapter will eventually fail. I have several that are cracked. You should fix that.Weird, looks like it could use an upgrade to breathe better.View attachment 293633
