- 2:54 PM
- Jan 8, 2016
- Farmington, CT
I hear ya... I really do. For me its just not worth the risk. But to each his own. Let us know how it goes!
I might add to the above post after being around every aspect of building automotive engines I have adapted both machining methods and assembly methods on various engines .Chainsaw naturally are much smaller than say a Ford 460 V8 but the same methods can apply .The tools just need to be smaller .For example the circlip installers I have made are almost the same as used in the factory ,again much smaller but they work .
Cranks in backwards......Worked like a dream, totally overthought this. Lubed everything with some mix oil and pressed the crank into the flywheel side first. Then the pto case onto the crank using a large pipe nipple. Stopped when the case gasket made contact and finished with the case bolts. Easy as can be, required little to no pressure from the press really. Seals look absolutely fine to me, I will of course pressure test at the end.
View attachment 73650 View attachment 73651
Made ya look ....[emoji2]Cranks in backwards......
I've put one in backwards. ..I learned ...I double check now...[emoji2] [emoji106]You sure did, lol
I'm quick ...lol [emoji2]He got me too
I bought the Stihl ones from DD...they work greatcirclip installer tool pics please.....( said the fat fingered arthritic old SOB in the back of the room )![]()
I have the 8mm one for the 200t..and it does work great with Stihl clips...unfortunately I find the bux tool one I have for the 12mm loves the Stihl clips only too. and the Meteor pistons im using more of now dont always align perfect with the stihl clips.I bought the Stihl ones from DD...they work great
I did have trouble with one clip ,in the Stihl tool but I think it was a hyway. ...not had any trouble with meteor or husky clipsI have the 8mm one for the 200t..and it does work great with Stihl clips...unfortunately I find the bux tool one I have for the 12mm loves the Stihl clips only too. and the Meteor pistons im using more of now dont always align perfect with the stihl clips.
if there is a better/cheaper way...im all fer a pic er two
I had a pic I thought I put on here .Give me a couple of days,lady friend is coming for a visit .--I'm old but I damned sure aren't dead .That aside it will take me a while to find it ,can't remember what external hard drive it's on .circlip installer tool pics please.....( said the fat fingered arthritic old SOB in the back of the room )![]()
