Ugly Stihl 064 overhaul
redline4
I'm huge in Japan
9:13 PM
Rosholt Wisconsin
Make sure the ring ends line up with the locating pins.
If there's no gap between your ring compressor and piston, it's correct
Slide the jug on
Start the bolts
And tighten it down evenly
Stick on the anti alien probing foil
redline4
I'm huge in Japan
9:13 PM
Rosholt Wisconsin
Intake onto the jug..
The tab on the bottom of the intake and the parting line on the top line up with the case halves and parting line of the jug
Because the carb studs are "twisted"
Flywheel on and nut tightened
Oil cap in
redline4
I'm huge in Japan
9:13 PM
Rosholt Wisconsin
Install this limiter
Install this mount...
In full transparency, I put the thing together before I noticed you need to install this 1st because you can't get to the screws with it together..
Set the tank on the case
Hook up the impulse
Start the intake into the airbox
redline4
I'm huge in Japan
9:13 PM
Rosholt Wisconsin
Intake is through
Install the upper av screw
Push in the lower av buffers.
It's easier if you make a gap between the case and tank, that's why that screwdriver is wedged in there
Install the screws to secure it to the case in all
redline4
I'm huge in Japan
9:13 PM
Rosholt Wisconsin
Push in the av buffer plugs
It almost looks like a saw
Al set me up with a new coil wire to replace the gnarly taped up one on here..
I screwed the new wire into the coil and set that in place
Fished the wires into the carb box
redline4
I'm huge in Japan
9:13 PM
Rosholt Wisconsin
Nice thread. I wish I had all this to read before I cussed my way thru rebuilding mine. you use the string trick for the intake rubber?
I do not.
I push it up against the airbox and work it around with a blunt screwdriver and needle nose pliers. If the rubber is in good condition one can be a lot rougher with them than most people think.
I have not had any issue, just need to watch what's happening.
5155
10:13 PM
pa
I like the alien foil.
Is that a Stihl thing or furnace duct thing?
Good read.
redline4
I'm huge in Japan
9:13 PM
Rosholt Wisconsin
Good read.
Stihl.
It comes in the gasket set.
It's either ment to keep heat out of the oil reservoir or, as mentioned, a place to hide your goods from probing aliens.
Or Stihls just need their own personal foil hat...
maulhead
8:13 PM
Home
Start the bolts
You don't have one of these in your tool kit?
I always see you using that free tool that comes with trimmers & some saws, in your build threads.
