XP_Slinger
They’re Just Saws
- 5:52 PM
- Feb 9, 2016
- Central NY
Set the needle lever flush with the carb body and try it again. I assume you’ve given the carb a thorough cleaning?OK did a rebuild.
Starter from 3rd pull again...
I adjustet needles all way in and 1 1/2 turn back, idles nicely, doesnt change rpm when i rotate it.
But simply doesnt want to four stroke, even going almost all way out.(H needle)
Crankshaft seals are new oem.
How high should be metering valve set?
Should main jet be two-way?
I can blow and suck through it, i know that some are single way?
Im sure that its something with carb, it doesnt leak, and four strokes when i flood it with choke.
what color is the coil? Should be black
