Two heavily used abused? Huskies 359
popopboat
10:19 PM
Found an ad for these two huskies on local "advertisement site?"
listed for 60$ for working one which has a hole in oil tank, but its sealed with rivets and silicone, but guy said that he will send me replacement case for it, other one was 35$, wasnt running and was supposed to be seized.
Didnt take a lot of time for me to decide that i must get them, as i always wanted to get my hands on husky.
** Forgive me for bad picture quality, this is my basement temporary winter setup as my garage is open-style so its quite cold out there**
Both looking fairly well, but that bar has some razor edges!
Intakes are very clean
**Cylinders look much better in person, than on pictures**
Sorry, forgot to take a picture before cleaning cylinders a bit, but there was a sh*t ton of carbon buildup.
Turns out that "seized" one isnt even seized, but has even better cylinder (left), working one is on the right, has 2 shallow scratches on walls (carbon fell off and scratched i suppose) but cannot really feel loss of compression.
popopboat
10:19 PM
More pictures.
Damn, grease your clutch bearings! All of three crankshafts are same, bearing is quite blue. Will see that can i do about this, only one crankshaft has a tiny little bit of conrod bearing up-down play, other two seem to be very fine.
As clutch drum weeble-woobled, it ate a clutch cover almost completely through on one of them, other one seems to be fine.
Both handles have a bulge at gas tank, is this normal or it bloated from seating with gasoline in for quite a while.
popopboat
10:19 PM
More pics.
Something has cracked crankcase on this one, but i doubt it was when chainsaw was running as there is NONE damage on piston/cylinder.
Thats a lot of filth overhere, it even formed ball shaped "things" i guess from vibrations.
Will have some satisfying time cleaning them up.
4:19 PM
Uncle Bill would roll over in his hospital bed if he saw those dry clutch drum bearings.
PS… Be careful sanding on 359 cylinders. I would estimate the plating to be only about .002 - .003” thick
popopboat
10:19 PM
Yep, honed it for 2-3 seconds just to check how it goes.
Can anyone tell me how "normal" is that bloating of the gas reservoar on handle.
popopboat
10:19 PM
Very well then about the tank, i thought that they were a gonners.
I will put metal clamps for sure, dont want it get lean.
Damn, had a hard time splitting this damn case, tried torching, pressing, hammering with wooden hammer (as i hammered my 064 easily), but this was STUCK, took this L shaped piece and welded them together, 3 holes and worked like a charm, literally with 2 fingers.
Dont worry, nothing was over-tightened, no risk of cracking a case.
What the hell, never seen so much carbon on bearings.
Hope that other, working one is not that bad.
XP_Slinger
They’re Just Saws
4:19 PM
Central NY
View attachment 227514 View attachment 227515
Bearings and seals are cheap. If I split a case I replace them unless I know exactly how long they’ve been in there.
popopboat
10:19 PM
Wasnt even doubting about seals, definitely a replacement.
Im thinking to get a normal sealed or unsealed bearing, maybe SKF or slacker and remove plate or seal and put them in, that way im sure that i will put high quality bearings in, anyone done similar?
Bearings should be - 6202 ? Right?
