markds2
- 6:48 AM
- Jul 22, 2018
- Nelson, New Zealand
The timing is just a hair (.15mm) advanced. @Deets066 recommended I try replacing the HT lead from the coil to the plug as well, just to eliminate that. That tune was just under the limiter but I agree it does seem a little lean after that cut. I have a feeling the coil is dodgy, I do have the option of pulling the flywheel and unlimited coil off another 066 I have, its a metal tag decomp so will be unlimited.I know you’ve said it was worse with more fuel. But It sure seems like you could fatten the tune up a little. Still have the timing advanced?
