Tree Monkey MS462 - PART 2
Woody
4:13 PM
New jersey
What we need is a test with a snellerized 462 with gutted stratos vs a treemonkey 462 with the stratos intact. If those times are about the same, then there’s no reason to be gutting the stratos and brad needs to revisit these strato saws.
deye223
AIR FUEL SPARK VROOOOOM
6:13 AM
Australia
Some pics of the 462 carbed
Metal limiter caps wtf! Scott defeated them , we think. Gotta try it
These look like the limmiters on a 261
My experience with gutted strados as limited as it is ..... Is they are fuel hungry pigs like the 660
XP_Slinger
They’re Just Saws
4:13 PM
Central NY
As mods progress, I think it would still be worth while to test with gutted & un-gutted intakes. Right now they’re dead even on a stock saw...but maybe one truly stands out over the other after its ported? Would be interesting to see those results.
Great work so far Scott and Julian, looking forward to the next round of chips flyin indoors.
Redbull661
661 hoarder (BlueBallz)
3:13 PM
MN
Interesitng tid bit. Scott was saying something yesterday about the gutted strato would give you less oil to bottom end. Went over my head.
Also, Scott had his camera running for the whole test. He wanted to show that he did change the boot etc. BIG video for his un ported internet connection. It was only at 13% when I left lol
Redbulls take - nothing I saw yesterday would warrant another test. But I wouldn't say it doesnt work on other saws.
Will say throughout R&D on the 661 there was a number of times scott and I thought the saw felt stronger but it was actually slower. Without the videod cut times wouldn't have known
XP_Slinger
They’re Just Saws
4:13 PM
Central NY
That’s a good point about the oil, never thought about that. I was always focused on getting an extra shot of mix into the transfers with everything gutted. Whatever you guys do from here will be interesting either way. Port Scott’s internet connection already! Lol
blsnelling
Friend of the Riff Raff
4:13 PM
Franklin, OH
I certainly can't say definitively, but I've had 261s with gutted stratos in commercial use for years with no issues concerning the bottom end.
Also, you're exactly right about the timed cuts. Perception is a powerful thing. I wish I had more time/wood to test.
4:13 PM
It's not really like that though. Gasoline needs 14.6 parts of air to burn efficiently. If you added fuel to the fresh air, your screwdriver or the M tronic would just tune it out
Edit
I think o_O
krustysurfer
4:13 PM
Western Lower Michigan
Edit
I think o_O
are the m-tronic saws replaceable with non electronic carb ?- go back to full manual control? is it worth the bother?
its why the local stihl rep refused to sell me a new saw and warranty it- he said the only way he would give a warranty for me is if i purchased the 880 for milling- he said i would void the warranty on the 661 if i used it with a alaskan slabbing setup - said the M-tronic would make the 661 run lean and fry the motor eventually... it is why i purchased a stock new 395XP however i am now worried about nylon being used around the main bearings!(unless i am wrong and they fixed that?) WTF HUSQY!......... im buying a old yellow saw to get the job done i guess- save the beauty queen for ?????????????????????????????? yes the husqy was 700$ less on the wallet new with a 28"bar ................... wife is going to get sick of my expenditures very soon............................ aloha and thank you mad saw scientists for all the beta.
4:13 PM
@Redbull661 did they feel any different in the torque they had? If two saws get the same cut times with stock chain, but one has more torque... then that is the more powerful saw, because you can run a more aggressive chain/or gear it up with a larger sprocket and it will be faster. Or it can handle a longer bar. At least that’s my thinking. Thanks for doing this test, makes the mind think for sure.
XP_Slinger
They’re Just Saws
4:13 PM
Central NY
Edit
I think o_O
Valid. Always looked at it as increasing volume/area, kinda like a boost port. BUT, that’s just a thought. I don’t think well, so I’ll stop interjecting theory into Scott’s 462 progression...lol
tree monkey
3:13 PM
wi
I just wish you would answer my questions
