Too much piston-bore clearance? Piston slap? Video
Stevetheboatguy
5:57 PM
Nw IL
Just so you know. You really need to measure the piston at the skirt not the crown to check for excessive play. The crown is always undersized to compensate for expansion when warmed up. There is no such thing as a truly square piston. They are all a smaller diameter at the crown and slightly egg shaped. Once they warm up and expand they are more closely to true square. Cold they are anything but.
Steven
cuinrearview
Handy dood
6:57 PM
Dowling, MI
Steven
You're lucky your name's not @ramrat
67L36Driver
5:57 PM
Easy to tell on this one. [emoji2960]
Actual skirt clearance was .070”.
popopboat
12:57 AM
Steven
Yep, at skirt its a tad bigger than than the thickness of double-sided razor, which means its around 0.006"-0.007"
But i guess it would be shame now, when im doing a complete rebuild of it, to cheapskate on pretty much most important component.
Ill just put aftermarket one, and as im not a heavy user, and im always using atleast 40:1 it will last me a long time.
cuinrearview
Handy dood
6:57 PM
Dowling, MI
The only ‘wear’ you get on them is when the piston seizes up and galls.
It’s crome plated.
The plating will will wear too. Just at a slower pace. I work with coated and SS tooling every day that is worn but aluminum not much thicker than foil.
Wonkydonkey
Plastic member
11:57 PM
Sussex, UK.
How about cylinder walls?
i bought the saw as a working saw, I pulled the plug, it was grey. Pulled the muff and saw the piston.
Now it was a rebuild saw.
I clean the cylinder up .he mastermind way al is good
You can read my thread
