- 2:29 PM
- Dec 3, 2015
- Banner Springs Tennessee
That's just a few of them. lol
...and here I felt bad that I had one I didn't need! ha-ha Oh well, if anyone else doesn't have a bucket of them and wants it, my offer is still good. I know it's aftermarket, it's a good specimen as far as they go, good casting, holes centered, ports chamfered. Port timing? I don't have an OEM one to compare to. I wouldn't have offered it up if it were total crap. The other cylinder I received with this one I will be trying out, it fits a MS440 project saw I have. I did my best to measure the ports to the Stihl one with the back side of a dial caliper and everything was within a few thousandths or so. I just ordered a close out Meteor piston and rings for it from HL, so it looks like the project is going to move forward now. If it turns out it sucks, I'll try reviving the Stihl cylinder with the treatment from the Mastermind video, as it really isn't that bad, mostly the piston. The reason I'm trying to keep costs down is there is a young man I have in mind for this saw, and I know his money is in short supply, so we do what we can do.
Anyone have a spare oem 024 cylinder ?
Is there an unlimited and limited or just one for this saw?
Also it has a Tilly carb is that preferred or should I be scouring Ebay for a better option?
The tilly is sufficient for solid woods port. What are you trying for with this one Dave?Is there an unlimited and limited or just one for this saw?
I need a coil and wiring I have kill switch and flywheel but thought I could get a coil aftermarket but I was wrong.
I want an unlimited coil if such exists.
I need what looks like some type of buffer/grommet for the top cover.
I need a fuel line if it is something special, I have bulk tygon and Echo fuel line if it is a standard size.
I need a top handle - I assumed I could get one from China but no luck.
I see Bryce has a full wrap for about $80 if anyone has feedback on if it is decent or not.
I also need what looks like a needle or something on the clutch side of the tank handle
finally I need two different grommets for the top rear deck of the cases
