The Swap Meet Thread
Marshy
WFO Cutting
5:09 PM
Mexico NY
I've got a 20" 3/8-.058 Bar and Chain setup that came on a 359/Small Husky Mount. I have no other 3/8 - .058 chain so this is the proverbial red headed step kid. I would love to swap it for a 16" 3/8 Small Husky bar and chain for a saw I'm building as a gift. I can get pictures of my setup this weekend. Chain need not be new nor the bar, just serviceable.
I have some new premade loops of 62DL Oregon chain but they are all 0.325 pitch. Does that interest you at all?
KZ1000
5:09 PM
Ohio
I could use a couple of the inserts that hold the brake handle on a husky 51/55 etc. I need the inners and outer parts and the screw if you have them, thanks.
Jon1212
Birch! Please.....
3:09 PM
Utah, unfortunately.....
@Jimmy in NC I might be able to come up with something in 16 or 18". What saw is it for?
Jon1212
Birch! Please.....
3:09 PM
Husky 350. I think it should be a .325 saw but he is set on a 16" 3/8 saw. He is a good friend so I will make it happen.
I'll see what I can come up with in 050.
I know I have a new 16" Power Match in K095 but it is 058. I do have some .058 chain, so I can spin up some 60dl loops to go with it. Lemme know...
tickbitintn
4:09 PM
middle tn
Anybody have an oil pump and drive for a Mac 4900??
Or know where to get one?
Did a quick search and came up empty...
Sent from my XT1254 using Tapatalk
skippy
Husqvarnas Sawyer
5:09 PM
Pennsylvania
Jon do you remember if I have any of these k095 bars ? I did not sell everything
Jimmy in NC
5:09 PM
North Carolina
I will check with him.. .058 may not be an issue for him.
T.Roller
5:09 PM
Southeast, TN
I'm hunting a clutch for a 044/440, the dust cover between the clutch and oiler, the air filter stud, and mounting bracket.
GoBigBlue1984
Bluegrass Fart Knocker...
5:09 PM
Kentucky
Aftermarket coils or oe coils? How are the aftermarket coils? Never used one before.
4:09 PM
I use OEM coils when I can. Some of them are getting harder to find though. The 046/460 and the 066 poly flywheel/660 use the same coil, so that helps with the search.
GoBigBlue1984
5:09 PM
Kentucky
Ok, thanks for the tip. This has a poly flywheel.
PogoInTheWoods
5:09 PM
Ohio
Need a 503-2210-02 10mm x 1.00 x 14mm hex flywheel nut for an older Model 61 Rancher. Evidently NLA according to my dealer even though that size was used on lots of 1xx and 2xx saws of the day. 503-2210-03 is what's now available through the dealer but is a 17mm hex head and is too large for the recoil cup to fit down over it to engage the pawls, let alone allow the recoil assembly to fit properly.
They're out there for a couple bucks plus $10.00 shipping. Uh, huh. I'll take five...
TIA if anyone can hook me up.
