The Swap Meet Thread
Shane¹
6:52 PM
Kentucky
Good morning gents. I'm looking for a 7900 cylinder in good or repairable condition.
I have a 7900 and 7910 cylinder but no piston 7900 had some transfer it is not as nice as 7910. I am not going to get around to using them soon so I would probably let one or the other go send me a message of interested
eugene89us
OPE Member
5:52 PM
Mississippi, United States
Does anyone have a spare red Dolmar coil they would be willing to sell? My saw would specifically take 181 143 210, but I understand those are rarer than diamonds. I am willing to give up 1,000 rpm with a red 181 143 204 coil that was meant as a replacement for PS-460, 500, 510, and 5100 saws. Thank you.
5:52 PM
Ok gents.....I need a few 6400-7900 parts for a saw I'm doing for Steve The Boat Guy's dad.....
Air filter base, carb screws, and the plastic tubes that fit inside the carb.
AV clamp that goes on the handlebar.
AV spring that goes on the jug.
Choke lever.
Carb adjustment rubber boot that goes under the recoil.
And.....a complete Makita blue recoil.
Have cash, or parts to trade.
farminkarman
I like the red & black ones
5:52 PM
Neenah Wisconsin
Choke lever.
I might have a few things you need.
Powerstroke Cowboy
4:52 PM
Montana
Choke lever.
I've got a few parts as well. Just picked up a parts saw for the parts I need.
I have a recoil as well. It'll say 6401 or 6421 on it.
If @farminkarman got you set up I don't want to step on toes.
5:52 PM
Greg, you are a lifesaver. Thank you.
David, Greg called to let me know that he had a parts saw he was willing to part with. He had everything I needed. Thank you for the offer sir.
Nate.
3:52 PM
Northern CA.
I’ve got a Good used crankcase for a 562, If anyone can put em to good use they’re free. I installed a new short block but there’s no reason these can’t be used. The crankshaft has some slightly banged up threads on the flywheel side might be salvageable 🤷‍♂️. The previous owner took a hammer to it….
Shane¹
6:52 PM
Kentucky
Are these the newer style cases I think I have an old saw with 5 bolts instead of 6? Or does anyone know if you can use either of you have both cases?
Nate.
3:52 PM
Northern CA.
I’d have to check but I think my saw was a 2016 model.
HumBurner
3:52 PM
Humboldt
@Oldbuzzard
nv656
3:52 PM
Nevada
posted in the homelite forum, figured here as well. Went through a few more bits. Homelite 750 parts
nv656
3:52 PM
Nevada
Wb3a carburetor
nv656
3:52 PM
Nevada
More 750, also have miscellaneous bolts
