2:24 AM
I'm glad Wilhelm put this thread in the new post searh with his recent posting.
I am trying to locate a HD filter spring clip retainer for my 7910. All I can find is the full conversion kit at HLSupply for $80.
I PM'd @166 but have never heard back.
I believe the part number is 038118450
TIA for any help provided.
Can be had from Germany, in stock, 7€
The whole HD kits are NLA in Germany, go figure!
ajschainsaws
Axes never run out of Gas
1:24 AM
South west UK
Oh just for giggle I will,
Durex it’s something we get in the PNW
We had some chain oil for sale over here and they put these sort of pictures on it but they got too many complaints being sent to trading standards so it finished after a couple of years
8:24 PM
I have been told a 79xx won't oil a 32''
I have yet to put one on mine to find out.
The oil pump control bolt is plastic and the knob on the end wears down over time. A new rebuild kit is cheap though, and comes with a standard and high output bolt. They will oil a 36 with a new control bolt. At least for a little while…
2:24 AM
As far as I know, no OEM ones!
It can be read here and there that unlimited AM coil for other saw brands have been successfully modified/adapted and installed.
If Your saw is not exceeding its coils rpm limit in the cut then You don't really need a unlimited coil in Your saw.
2:24 AM
Can You get the clip in the US or would You like one from Europe?
Sagebrush33
8:24 PM
Upstater
Hello Wilhelm, I haven't sourced one over here. No one has given me any links to follow up with either.
I would be delighted to have one from Europe.
Thank you!
I will check back later today after work. I was just getting ready to logout and start my day.
Been super busy. Winter's coming.
Again, Thank you.
old_sir_henry
2:24 AM
For all you DOLMAR and SACHS-DOLMAR fans I have another pretty obscure saw to show:
A SACHS-DOLMAR 1100, an electrical saw sold in the 1980s.
Apparently this is a yellow coloured variant of the SACHS-DOLMAR 260 or maybe
its predecessor SACHS-DOLMAR 200.
All these were Japan built relabeled SHINDAIWA saws.
I never ever have seen pics of this model before and never have found any
reference to it anywhere so I assume it hasn't been sold in quantities.
The saw runs quite fine.
Sagebrush33
8:24 PM
Upstater
If pluged in to 220v will it pull a 36'' chain?
Convert to 3 phase for a 60'' bar?
Don't answer that. :D
Tis an interesting piece of rare history in awesome condition.
2:24 AM
Nutball
7:24 PM
Mt. Juliet, TN
I have a Makita 9010, writing on the box and elsewhere mentioned a 30" and 29" bar, no bar included when I got it, but was surprised to find a 92dl chain. I figured it must fit a 29" bar as a Stihl 30" as they measure theirs uses 91DL, turns out the 1970's Oregon uses 93DL. I noticed that the oil hole on the Oregon bar does not line up with the oil slot on the power head, but the bar is a Stihl large 14mm mount just like the studs. I wonder if there were different bar plates with different oil slot locations to accommodate the different bar mounts available on the 9010, and if they got it wrong somehow, or if Oregon got it wrong? Anyway, I'll just drill new holes a little lower. Pics tomorrow.
SOS Ridgerider
Muffler Modded Member
8:24 PM
Central CT
There were some saws sold overseas with a hardnose 29” or 30” bar. I’m not exactly sure how many DLs they take, though. @RI Chevy would know, he has a bar like that.
The mount on the saw is a D033, which essentially is a D009 with a 14mm slot. That was meant to be ran in the front mount holes in the case. There’s a second set of holes meant for D009 mount studs. To do it so it looks factory, it’ll require a new bar plate, which is NLA, and a new clutch cover.
If you just want to get it done, you can drill out your existing bar plate, install the 9mm studs, drill out the clutch cover, and run a large D009 mount bar.
Or, you can grind the slot on a D009 bar up to 14mm.
Modding a large Stihl E031/3002 mount bar to work on these saws is not that difficult either.
You can also grind flats on the 14mm studs, and run a D009 or D025 bar, depending on how much you take off.
The last way I’ve seen done is to machine a recess on the front holes, so you can run the D009 studs there, so the shoulder on the stud fits flush. It’ll make it look pretty much stock, which is nice.
Many ways to skin that cat. Lol
Am I rambling yet? Feels like I am.
