6:17 PM
M2theB
12:17 PM
Central Mass
You need a new test log!
Runs nicely.
Come try that 9000 at my place, I am free tomorrow!
I got plenty of beer, fuel and oil.
And Sun it looks like.
Your right, that one has a few carefully placed cuts left in it but that’s it.
6:17 PM
40+℃ if You like weather like that, I don't.
It is supposed to get much hotter the next two weeks.
6:17 PM
Nice. Did you gut the muffler yet? 9010s are tug boats!
They are certainly heavy as tug boats, so many quakes here in Croatia this last year and the closet never moved one bit!
By the looks of it they may actually have held the whole house down during the past couple storms.
6:17 PM
I went as far as not putting the spark screen back in if that counts
That's NOT enough, I run mine like that.
The mufflers outlet hole is way too small!
I think you just flip the studs if you have the right cover/ kit. There’s a US Australian version I think.
There are two different stud versions, my PS-9010 has threads in its case for both front 14mm studs and rear 9mm studs.
I have both stud versions, just need to drill rear stud holes in the bar plate and clutch cover, or turn down the 14mm front studs.
I only have one 14mm mount bar, but several D009 mount bars.
Once I swap or modify the studs I will most likely never use the 14mm mount bar again.
RI Chevy
12:17 PM
earth
The few that I have seen have lots of stuff inside that need to come out in order for it to breathe the way it needs to.
And the muffs must way 2 to 3 lbs. Lol
Need to be gutted.
12:17 PM
Need to be gutted.
Yes. I found performance is sorta lacking for a 90cc saw in stock form compared to others in it’s class. A muff mod wakes them up.
Sagebrush33
12:17 PM
Upstater
They look like closet queens.
:couch:
So clean. Then again, when ya keep em in the house, they have to stay spit shined. :)
I keep mine in the house too. Until I finish getting the garage cleaned out and organized.
Sagebrush33
12:17 PM
Upstater
