The official OPE daycare thread
greystone mountain man
1:15 AM
East Tennessee
hacskaroly
2100 Fanclub Member
10:15 PM
Northern Idaho, Ehh
FedEx brought me this Chinese powerhouse today 😂 for some reason the chain brake and or sprocket were tight but they loosened to normal after some warming up and throttling up.
Even though it is a top-handle saw, you should use both hands, no telling when it can catch and go sideways. The only thing you should really one-hand is when riding an atom bomb, then you can use your other hand to wave your cowboy hat. :D
LAWN BOY
Pothole
10:15 PM
Merrill, WI
Excellent advice @hacskaroly. Don't pick up bad habits from Bucking Billy.
BTW, Your freaking chain is too tight for sure and back out the L screw a little at a time to get rid of the hesitation Logan.
After 1 more cut the chain was too loose so I'm not sure what's going on there. Will readjust it tomorrow. I was gonna adjust the carb but the screws don't have a head for a screwdriver. They're plain...
timg
1:15 AM
Keystone State West
It actually looked as if the chain wasn't seating in the top of the bar rail. I saw light in the driver to rail area on top in your video. Could be some burred drivers or incorrect gauge. It's Chinese so look it over before it fuggs up.
Lnk
Stock Chainsaws do not suck!
1:15 AM
East, TN
Screws are probably splined. You should pick up a set from Ali express or snap on. Has a driver for all those special screwdriver prevention screws. Also, your chain is probably !made out of lead, and has stretched. Give it a good blowjob and it will be fine.
hacskaroly
2100 Fanclub Member
10:15 PM
Northern Idaho, Ehh
You probably need one of these tools, they work great on some carbs that have a sleeve over the screws, when you push it in, it pushes back the sleeve allowing you to turn the screws:
1:15 AM
East Tennessee
Or stroking your one eyed weasel 😎
LAWN BOY
Pothole
10:15 PM
Merrill, WI
Here are the adjustment screws…. Just now realizing/wondering if the shiny Phillips one labeled T is an idle screw…. At first glance I assumed it was just a screw holding the plastics together.IMG_0337.jpeg
hacskaroly
2100 Fanclub Member
10:15 PM
Northern Idaho, Ehh
Give it a slight tweak while running it...that will let you know!
