sawfun
- 8:29 AM
- Mar 24, 2016
- Portland Oregon
Remember those old saws usually had low horsepower ratings. I'd bet the 895 would have been around 6.5 to 7 at best. And it may be difficult, unless you disconnect the governor to get a no load rpm. These are not like modern direct drive saws at all. Normal rpm in wood is prolly around 9k to 9.5k in wood and when loaded heavily with a long (60" +) bar, mine opens the reeds and just gains massive rpm screaming at what I would bet is around 12.5k or better. However remember that is at a 2:1 drive ratio so little chain speed. You can make up for the lower chain by running a much larger tooth chain, as these were designed to do in order to make them more viable. If you want an 895 experience, fund a big old growth log, run a LONG bar, no not a paultry 36", use 1/2, 9/16, or 5/8 full chisel chain, hang on and enjoy. They ain't none too slow equipted in such a manner. These are not firewood saws, but rather serious big timber machines from days past when there was such timber readily available.
