- 10:06 PM
- Jan 28, 2016
- Dike, Iowa
Some while back I stopped by fellow member Ike Holt in IN and got a load of parts, several saws, and his BP-1 to get going again. The BP-1 was finished and returned a few weeks ago and I have been working on the CP70L for a couple of weeks now. It was very clean and appeared to be very low hours, but it would hardly crank over and felt stiff and crusty. Following the good advice and example of Randy Evans a complete tear down was in order.
I did not take a lot of photos but when I pulled to cover off the oil tank, there was water inside... When I split the crank case it was badly corroded on the bottom half, evidently the crankcase bottom/oil tank is made from magnesium and the cylinder/block is made from aluminum. I cleaned it up as best I could but had to resort to sandblasting to get all of the corrosion out.
I used some Lock Tite two part epoxy to coat the inside of the crankcase bottom.
Mark
Mark
