8:34 PM
That linkage probably is better than those rubber bands .Where did that brain storm come from?
heimannm
7:34 PM
Dike, Iowa
I like those snubbers on the 10 Series, makes it easy to disconnect the choke and get the carburetor off.
I posted my big H&S spike for the large frame direct drive saws recently, just a reminder:
I just got another one off e-Bay, smaller overall in size. I went ahead and sandblasted it and shot it with primer. I also have one that fits the large frame gear drive saws. This one had seen some hard use and had been cracked and re-welded.
Mark
T.Roller
8:34 PM
Southeast, TN
Mark
My 125 had a welded spike like that on it. Thought it was homemade but I'll have to look closer
Lee H
5:34 PM
cape cod ma.
I have a good friend that lives in Cali, H&S felling dogs was started in his grand fathers shop
out in the back room. Later they had moved. I have quite a lot of those dogs that are on many
saws. Homelite, Mac's, Jonsereds, Stihl, Sachs Dolmar, etc.
Steve
Excellence!
7:34 PM
Frank bierce
5:34 PM
You think $500+ shipping is too much for this. I’m a bit on the fence. Been wanting to get one. Looks te be a little rough around the edges. Sounds like it is a good runner though.
48726D9F-F1CA-4171-9BB7-1E82BC116BD7.jpeg 92E4C58C-7025-493A-B24C-BC104E48B42C.jpeg EEE10FF0-C7C5-4FFB-B5C9-02519F77D719.jpeg 5A21135C-BCBE-411A-BF49-D389DB125151.jpeg
Ikeholt
8:34 PM
indiana11
That's about as cheap as they get. I see the top cover is broke. I have a pretty good black one you can have. At least I think its around somewhere.
heimannm
7:34 PM
Dike, Iowa
On the plus side, it should have a steel sleeve so you could bore it oversize if needed.
On the negatives, someone cut the AF cover, saw dust screen is broken (Bob Johnson has NOS, I have 3D printed replacements), muffler cover is missing, home made spike (now you may wish you'd have kept that small H&S), and something is going on with the compression release...could be just the anti-vibe mounts are broken but you should check it out.
Mark
T.Roller
8:34 PM
Southeast, TN
Mark
I have a question. Did the CP with the round muffler ever come with a cover over the muffler
T.Roller
8:34 PM
Southeast, TN
heimannm
7:34 PM
Dike, Iowa
All of the IPL's that I have show the CP125 with just the round muffler, no cover.
I have two CP125 and one CP125S and none of them have a cover over the muffler.
There was a sort of retro-fit kit that would allow you to install the rectangular muffler and cover.
Mark
8:34 PM
For that matter I don't have that much money in two 125's and a 105 but then again I bought them before they became so popular .
brandonstclair20
8:34 PM
Starkville
I have a Mcculloch super 250 that I rebuilt the carburetor, and change the points and condenser. It has nice blue spark but it will not run on gas in the carburetor. What could be wrong?
Steve
Excellence!
7:34 PM
Your Reed valves may not be sealing properly causing no case compression. How is cylinder compression? Should be over 100psi. These saws run very well around 125psi.
Yukon Stihl
5:34 PM
Great White North
Speaking of 250's...
Is there any significance to a Belgian 250?
I was going through the 250's i have today to see if anything was worth saving and found the Belgian connection.
