exSW
'Cause Thomas is a poopyhead
- 8:18 PM
- Dec 23, 2015
- United States
The 5.3 cubic inch,87 cc engine is my favorite of all the big McCulloch reed valve engines .That one they got right .
There is a trick however on the 80 cc units like a 250 .If you can find a .050 groove bar and run 3/8" chisel with an 8 tooth it will cut a lot faster than with .404 .Surprising with that set up it takes 72 drivers on a NOS 18" Mac bar .I chanced upon one still in the cardboard wrapper . NOS Oregon probably 50 years old .
Don't want to reinvent the wheel just want the Mac part #.Was wondering if you ever found a solution for yours.
Wow what size bar you got there?
Super 250? How does it pull that long of a bar?Remington branded Windsor.050 38" roller. Dad bought it for a SL-55 that I still have. Circa about 1972.
Haven't found out yet. Hence the needed bearing.Super 250? How does it pull that long of a bar?
Oh I see. I have a couple part saws. I'd gladly send you a used bearingHaven't found out yet. Hence the needed bearing.
While on the subject I had adapted a standard Stihl mount 32" bar which I ran on that same 250 I have the .050 bar on .It pulled it no problem . That bar now is on a souped Stihl 038 Mag .--and it pulls it no problem .
