- 6:57 AM
- Jan 28, 2016
- Dike, Iowa
For the record, the big bore Walbro SDC carburetors (SDC 18 & up) all have the same throttle bore and venturi diameter; 0.812" throttle bore and 0.750" venturi diameter. Most of the Tillotson HL carburetors and the Walbro/MAC carburetors used on saws have the 0.812" throttle bore but a .687" venturi diameter. The smaller Tillotson HS carburetors (i.e. 43) matched the smaller SDC carburetors at 0.750" throttle bore and 0.625" venturi diameter. The larger HS carburetors (70, 71) matched the HL and MAC carburetors at 0.812" throttle bore and 0.687" venturi diameter.
The HL272 used on the welder is 1.000" throttle bore and 0.875" venturi diameter.
Some of the MAC BDC pressure pulse carburetors (BDC2 & BDC4) were 1.375" throttle bore, The BDC14 was more conventional with 1.375" throttle bore and 1.125" venturi diameter.
It was interesting that there were a number of the smaller 10 Series saws that came with the bigger SDC's, and some of the bigger 10 Series and large frame saws came with the smaller SDC and HS carburetors...go figure.
I have and SP125 that came with the smaller HS, installed a bigger SDC and the difference was remarkable.
Mark
Mark
