Maintenance Chief
- 11:51 PM
- Jan 4, 2020
- South Carolina
Mark , the Lombard comango has a solid linkage peice ( connected to the tillotson carb)that lifts a piston up from a check valve for the oiler, its right below the carb box.Here is a different one for the McCulloch crowd, Pro Mac 61, one of the Italian McCulloch saws. Mike Acres site has it listed as a Pro Mac 60, 1998 manufacture date, and 59cc built in an Italian McCulloch factory.
Back story on a big group of saws I picked up in Oregon a few years ago...seems that Ormark/Oregon chain manufacturer were testing chains, I believe for kick back propensity, and a saw shop in Eugene (Mr. Chainsaw) got the saw when they were done. If you look at the cushion on the front handle you can see where a section was cut away for the saw to be clamped in their test rig. The tape on the trigger release was also a by-product of their testing.
Mark
Since the oil tank is pressurized with compression ,the saw running a full throttle would be getting " full oiling" ?
