- 12:15 PM
- Jan 14, 2016
- North western Ohio
More on the grease gun .You could also again using an old spark make an adaptor to install an air chuck which could do two things .First show if it's stuck above the ports .I so it would hold pressure .Secondly it could help to push the penetrating past the piston . The two 18 MM devices I used to unstick a 300 Ford 6 and the 14 MM to unstick a Partner p-100 .BTW if you try this I would suggest unbolting the cylinder thus lifting the cylinder off the piston in case it's stuck by the crankshaft
