PogoInTheWoods
- 3:48 PM
- Apr 23, 2016
- Ohio
The flywheel bearing uses the clip on both styles. The groove locates the crank in the same spot with either bearing. The seal is press fit either in the crankcase bore or the extended race inner bore. Depending on the bearing/seal style used. The pto bearing and seal in the 54cc engines is just sandwiched by press fit in the crankcase bore. On the 57cc and up saws the pto bearing and seal is pressed into a sleeve that is sandwiched into the crankcase. The early sleeve uses a ring like the flywheel bearing to key it. The later uses a pin in the oil tank half and a hole in the bearing sleeve to key it.
Are you sure about that? LOL
The bearings from 54cc all the way up to 82cc are the same
This is still an inaccurate and misleading statement any way you want to spin it, but good on you for the detailed follow-up clarification. Why search for a 63429 and seal thinking that's what you need if an easier to find (and probably much less expensive) 67905 and seal will work just fine?
Interchangeable, yes. The same, no.
Photo courtesy of Mark from a similar AS discussion. I believe he also may have posted it here recently.
