Squareground3691
- 11:27 AM
- May 1, 2021
- New England
Large mount chassis’s assuming,,
Yep I've done that countless timesUpdate: I swapped clutches and installed the one with the 64857 pawls and it grabs every time now. Pulled like 20 times and no turn over, not even a pop...then I remembered "the switch"...yes, that one. Put it in the "ON" position, two pulls and it fired up. I have put it on the shelf for the moment until the carb kit shows up. Now to work on cleaning up some of my other Mac projects!
Man that thing is sweet!Little Kart saw action, View attachment 440033
This what I found online:Need some help with this bar, what models dose it fit? D196?
Does anyone have a flat back to sdc addapter part# 83722 that they would sell? I can make one if I need to, but I figured I would check before I spent 5 hours on the drill press and die grinder.
I have 25 of them in a bag in the attic somewhere, but I haven't been able to find them for over a year...
Ryan Zuppe was selling some 3D printed ones on eBay but he's since pulled the listing. I might still have one up there but I'd have to look.
Mark
Thanks for the offer.Is it plastic or metal? I would like to try to keep it as close to corect as possable. I'll see if mark can find one first.I think I've got one of Ryan's 3D printed ones at the ready if you want to try it...
Thanks let me know if you can fined it.I have 25 of them in a bag in the attic somewhere, but I haven't been able to find them for over a year...
Mark
I wood if it wasn't a 20 hour trip lol.I'll make everyone the same offer, come and look; if you find them you get yours for free...
Thanks for the info. Let me know if you run into one of those adapters.The flywheels will interchange but the 440 flywheel has pawls for the starter and the 795 does not. 795 has the pawls in the clutch.
440 calls for 60251 and 795 calls for 60251A for the crankcase bottom cover (stuffer). The gaskets used on both are the same so I'd guess the parts are interchangeable as well.
Mark
The MacCat is minty! I have 2 in pieces still. I’ve never heard of the pole cat version, cool!
