- 6:04 AM
- Apr 18, 2024
- Canada
Okay, so just to describe again. Because felt like prime goes in runs it’s course and either carburetor not drawing ( might be as I tightened one side of carburetor and may have disturbed the impulse hole) as it runs bar/chain for duration of prime with no issues. Also thought low had to be adjusted higher to compensate for drag but carb so damn frustrating, the slightest change and its back to balancing.Typically, if you have to retune it with a bar on, your PTO seal is shot
I hope not a bad seal, ordered it months and months ago. When I went to put on noticed it had a curled lip. But not convinced it not carb, saw feels solid . If it is seal will replace and replace carburetor. Going over yours and others conversations about carburetor options.
Also oilers work fine, I thought turned all the up but were turned down all the way.
