- 12:20 AM
- Jan 28, 2016
- Dike, Iowa
With the chip, the flywheel controls timing, the 125 flywheels can vary quite a bit! I would check your flywheel key slot for play, sometimes you can get a little more or less timing., I have seen some of the 5° flywheels at 7°, and heard of +9°, you can always retard the timing with a cut keyI finally got the CP125 back on my bench, and I figured out why it didn't have any spark. After setting the gap I got it to pop, but now I have a new issue. It always fires at the same time, mid-pull. I checked to make sure the flywheel key was intact (it was) and tried flipping the leads on the chip (the points are gone), but there wasn't any change. The only thing I know is different is the original coil is the upper in the 2nd pic and the one that replaced it is the lower one. Any chance they're timed different?
View attachment 399461View attachment 399462
Aren't the 125s fun to run though?I ran mine for the 1st time 1 1/2 yrs.ago & it was an awesome experience!Ed - Same fuel/oil tank as the Mini Mac's. If you don't have/can't find one locally let me know and I'll put one in with the saws when I send them back. I'm thinking next week will be a Mini Mac week, I have a least 4 in the shop right now that folks want fixed up.
Last Saturday was a pretty good Mac day, I used my junkyard dog SP125 to drop the big stick and buck it up, and my 7-10 to noodle the rounds into more manageable pieces. The neighbor in the red house was trying to work on his deck, not sure he could hear himself think.
Even when cut into 4 pieces, those chunks were difficult to manipulate into the splitter.
Mark
Mark,I believe I have a fuel/oil tank here for a E.B.2.0that I got from Bob J.about 5 yrs.ago.I never got around to putting it in the saw & someone helped themselves to the saw.Ed - Same fuel/oil tank as the Mini Mac's. If you don't have/can't find one locally let me know and I'll put one in with the saws when I send them back. I'm thinking next week will be a Mini Mac week, I have a least 4 in the shop right now that folks want fixed up.
Mark
Thanks,SteveVery nice!!
Ed where is it leaking I've had good luck plastic welding the tanks. I use one piece of similar plastic to use as rod and just fill weld with plastic welding iron. Kinda like a soldering iron.I was gifted an SP40 & it has a leaky fuel tank.What other models used the same fuel tank?Does anyone know if there's a product out there that's like Red Kote,but for plastic tanks?
The saw is almost mint,has had little use.
I always like the shorter clutch covers. Nice work on this one.While we were working on the oak tree pictured above, someone dropped off a few boxes of used saws/parts at the shop.
Son Jeff was helping me get the parts cleaned up and from the pieces I put together this PM700.
I used one of my early version 3D printed sawdust screens.
NOS muffler from parts, and a modified PM style clutch cover from one that was busted up pretty badly. I doubt it would keep up with my 7-10 but I must say is doesn't do badly with the 20" bar buried in my oak test log.
Mark
