Steve
Excellence!
7:20 PM
Wow,this place is dead.I understand why folks didn't work on saws in the summer,but it's Nov.now,Lol.Maybe got 'em all fixed & out cutting firewood?
I picked up another PM55 for $50.Supposed to have only 90 psi.I'm supposed to get it today.
I also bought an Eager Beaver 2.1 for $18.Supposed to have good compression & spark.I'll get that next week.I have another E.B.2.1 here that I bought about 5 yrs.ago.It runs like a champ,but neither one of the oiolers works.I put a new oil line in it & a different pump & still it doesn't oil.I take that back,the manual oiler will work till I put the cover back on,& NO the line isn't being pinched.Just being a contrary PITA.
Full time job and family and property chores kinda eat into my play saw time a lot anymore. I'm working on my Makita 4300, a husky 350 and a 41 if that counts! :D
Dream
8:20 PM
Elberton, GA
Sounds like me.
All ive had time for lately are other color saws.
Ive got a 66 Hoosky that I replaced the piston kit and cleaned up the cylinder for a coworker.
Breaking it in so I could tune it, and the oiler pump quit.
Once I fix that and get it back to him, its time to put the 7-10A back together, then maybe see if the 1010 RHS I recently was gifted is going to be a runner.
Its a Mac 1010 "lightweight".
Same one Marcel Ledbetter used to clear out a beer joint I think.:):D
Maintenance Chief
8:20 PM
South Carolina
Thats part of the reason I like old chainsaws, its about the leisurely pace of tinkering with them, unlike the catastrophe crisis I deal with weekly in my job. They'll be there when I get around to them, but family, work ,and life takes president. Hell If you got a woman around that is half your time ,because No woman is with a man to play second fiddle to anything, as the saying goes" F*** around and find out".
The old saws are all my thing always occupying a small corner of my mind to mull over in the spaces of time when sitting in traffic,replying to email, painting walls, or whatever else old man time is picking my pocket with. 20220914_115809.jpg
edju1958
8:20 PM
Western N.Y.
edju1958
8:20 PM
Western N.Y.
I've got bad news & good news.First the bad news - whoever owned the last PM55 I acquired should be horsewhipped & then shot.I tried putting a plug in it only to find out that the moron made the plug hole so oversized that a plug won't fit.I ended up stripping the saw down for parts.They oversized just about anything they could,the handle where it mounts on the bottom of the saw was redrilled & oversized bolts put in.On the muffler they drilled holes through the cylinder shield & put longer screws through the muffler & cylinder shield & then double nutted it.Talk about a PITA to get them loose,especially when they're lock nuts.The coil is pretty much toast,the bozo put tape around the coil to hold the plug wire in instead of just replacing the lead.Probably explains why it had intermittent spark.I had to use a small pipe wrench to break the fuel cap loose.They must've been in the oil tank too because the allen screw was in the place of the regular screw that holds the auto oil pump in & the regual screw was in place of the allen screw that holds the tank handle onto the engine/oil tank.
Now the good news - I pulled the tank handle off the 2nd PM 55 to see why the oiler rod was binding.Apparently the oiler rod was not sitting in the groove under the tank handle,from what I could discern.Usually I twist the rod sideways a bit so I can lift the tank higher & have better visuals on it.Normally it seats back to the original position,but not this time.It still wanted to bind a hair,but as I worked the button it works fine now.All I need to do now is put the carb back on.Oh yeah,after I got it all back together I checked for spark & didn't have any.I tried another plug & had great spark.I looked at the 1st plug & saw it had a bunch of crud in between the electrode.I cleaned it out & had spark again.
8:20 PM
With old saws or in fact any saw you never really know what to have .So it's usable, rebuildable or just parts .You get enough parts you can build one .My next conquest is a hot rod 10-10 McCulloch which I think can be done .Very few would even attempt it but I'm the odd man out because I will . I have almost a year to get it done the way I see it for Ohio Saw Fest which has been years since I've modified a saw .I haven't forgot how though .:)
Steve
Excellence!
7:20 PM
And don't forget that it still ran well enough for years with any combination of the band-aids to keep someones family warm in the winter.
Let's see a new saw do that.
jacob j.
Only the weird
5:20 PM
Coastal Oregon
I was just thinking that today, while tearing down an SP-125 that my grandpa shoe-horned a CP motor into. An MS-881 isn't going to be around in 50 years for some schmuck like me to tinker on.
edju1958
8:20 PM
Western N.Y.
Old Bob Johnson would never work on a Stihl or Husky.He said that they didn't hold up like the old Macs or Homies did because the Stihls & Huskys were too high in RPMs.He said if you tear one down you'll see it's all shot internally.Most of 'em are burnt up.About the only way one burns up a Mac or Homie is by running it too lean or an air leak (which causes it to run too lean).
Scott Kelsey
7:20 PM
Wisconsin
Curious if anyone here has first hand knowledge on using one of these for a 125 and how to go about it?
