FergusonTO35
- 3:53 AM
- Jul 9, 2017
- Boonesborough, KY
The door has a push sticker on it, and I still pull.
Sounds like you got some green button pushers and that’s it. Most of the work in machining is the setupCoworkers handling a CNC mill 6+ months, even years, mass production:
1) Setting up a workpiece, machine runs into one of two clamps after drilling the first hole. Coworker doesn't know what to do for at least a 1/2 hour, decides to ask me. I take a look at the setup legend and the workpiece setup on the machine, turn around and ask "Is this clamp on "II" (mounting hole row)?". He takes a look and quietly answers "No!". To be clear, he was adamant that the workpiece setup was accurate.
The clamp was mounted two rows over, on "KK", which is in our case 1" into the spindles/tools way.
This happens all the time, these coworkers don't even get the idea of double checking the work setup they did when the machines crash into something, instead they start altering perfectly fine processing programs.
2) Coworker sets the mill up for a workpiece and gets a "Z- Limit Switch Error". "Z" is the spindle/tool axis, "-" is the spindle/tool plunge feed (+ is retract), limit switch error indicates the machine having reached its fixed machine parameter limit. Said coworker tinkers around, doesn't know how to solve the issue and starts altering the workpiece setup lifting the workpiece higher.
Simple solution is to either pull the tool out of the tool holder if possible, or simply utilize a longer tool holder (ER32/70 is short, ER32/160 is long).
In most cases the tool just needs to be pulled out a little.
A couple former coworkers managed to enter their machines service parameters, messed around in those and rendered the mill inoperable (backed up machine parameters needed to be loaded, easy fix but still undesirable). Needless to say those former coworkers didn't last.
3) Not knowing how to open (load), close (unload), copy, paste a processing program. All but one mill feature an "Explorer" style program management with tree like folders containing files. Tabs clearly stating open, close, save, copy, paste are plastered on the screen.
These individuals present themselves as the smartest smartphone users, yet they fail miserably using the mills Explorer style program managers.
4) Guy gets to process sample workpieces, meaning he uses and alters/corrects a new processing program pulled either from an USB stick or the companies network. At the end of the shift he shuts down the mill not saving the processing program. The next days morning shift has to redo everything he did to finish processing the sample batch.
Guy comes to work gets asked why he shut down the mill without saving the program, he answers "It said "OK" and "Cancel", pushing cancel didn't shut down the machine so I pushed OK.".
This is an example from one of our Windows based mills, when shutting them down while there is unsaved work the machine will warn You "You have unsaved work, are You certain You want to shut down?!" with OK and Cancel tabs. You are supposed to push cancel, open the program manager and save Your work!
5) A couple coworkers "collect" their spit/luggers in their mouth while waiting that their machine finishes its processing cycle, then open the machines safety doors and spit into the machine for every other worker manning the machine to enjoy.
The ground surrounding the mills is tarmac covered in iron dust and other dirt, including pigeon poo - there is no harm done spitting on the ground rather than into the machine.
These may not be "dumb" examples, but You can't handle a CNC mill and not learn the kinks it involves doing so!
Also, young generations have no work ethics.
Most my coworkers are aged under 40 years old, many under 30.
Lengthy post, thank Tou for reading!
Cheers
You hit the nail on its head!Sounds like you got some green button pushers and that’s it. Most of the work in machining is the setup
So boss co.es up to me the other day and is wanting to get some people rounded up to we can work out something to boost company morale.
I guess Im apart of the "Ministry of Happiness".
Call it the Department of hookers and blow.
It can either go over really well, or get shot down immediately.
Everyone gets a raise, problem solved.So boss co.es up to me the other day and is wanting to get some people rounded up to we can work out something to boost company morale.
Winning!Call it the Department of hookers and blow.
Escorts sounds classy.We have a guy here doing blow on his lunch break in the parking lot. The fine women he converses with may be defined as escorts though...
For some of us it's too late.Everyone gets a raise, problem solved.
Is getting rid of him one of the solutions? Coz I see a problem if so.So boss co.es up to me the other day and is wanting to get some people rounded up to we can work out something to boost company morale.
I'm surprised that anybody in an aftermarket shop could afford the good nose candy. I worked at one of the biggest new car dealerships in the state for several years, and that place was like real life Miami Vice. Lots of money, drugs, and hot women. Everybody had some kind of hustle going on. The service department had fake warranty work down to an art form.
