I saved over $500
OnlyStihl
5:17 PM
PNW
I had a brake job done on my Toyota FJ by a tire shop. I mentioned the leaky axle seal, and afterwards they told me they don't do that. WTF?
I called the Toyota dealer, and for 1 rear axle seal R&R it was over $500. Claimed it was a 3 hour long job. I did it in two, never having done this before, spending a lot of time getting the correct sockets, extensions, and constantly having to get creative with 1/2 to 3/8 socket conversions. And I'm doing much of this on my ass, walking back and forth for a different tool, etc.
I just don't know about dealerships anymore. Seems they are always trying to screw people over.
Now I'm trying to decide if I should do the other side, since the new seal was a 2 pack? Not a fun job!!!
Hinerman
6:17 PM
NE OK
Do the other one now, or do the other one later. You have it figured out now and can probably do it in an hour this time.
And yes, dealerships are a legal scam, imo
Jake Dykstra
4:17 PM
NW Washington
Gotta pay for them fancy shops full of snapon tools somehow. Yeah ridiculous what it cost these days to get shop work done.
Wanna see 500 turned into 5000! Buy a diesel truck and have it worked on!
Shane¹
7:17 PM
Kentucky
I would personally wait. If it isn't leaking I say leave it alone. In my opinion sometime messing with them creates a leak when replacing it is not necessary. I would also make sure the vent is not plugged because that will make seals keep blowing out and you won't get it sealed up no matter how many seals you put in it
OnlyStihl
5:17 PM
PNW
I'm going to do the other side in a couple of weeks. I'll watch the completed side, to make sure it no longer leaks. I did it right and trust the problem has been solved, but will wait to make sure. :thumbsup:
Sloughfoot
4:17 PM
Norcal
We have an FJ. On ours I've replaced ball joints, wheel bearings, CV axles and seals, taken the front and rear diffs out to get geared lower and air lockers put in. So on and so on. Ours is raised and we offroad it pretty hard so it goes through front wheel bearings, mostly from being submerged occasionally. Don't hesitate to message me if you get stymied working on yours.
Bill G
6:17 PM
Those fancy shops do not pay for mechanics tools, the mechanic does. Of course they do pay for high end diagnostic tools.
OnlyStihl
5:17 PM
PNW
I'd love to have a shop lift to easily get under the FJ, or any vehicle. As a kid, working on the underside of a vehicle was easy. Damn near impossible at >60 years. Just sitting on my butt to get at things is a PITA. My buttocks and thighs were screaming last night.
Stem
Professional Cup Stacker
7:17 PM
Pennsylvania
I try to do as much of my own work as I can, esp with Toyota (I have a '13 Tacoma). buying OEM parts from the mothership is bad enough.
oddsaws
6:17 PM
Bartlett TN
‘Stealerships’ is what I have always called em. I’m convinced that they take the actual labor time and add 1-2 hours. I will go there during a warranty period and that’s about it.
Glad you were able to get the job done and save that money. These days we need all the savings we can get!
Sloughfoot
4:17 PM
Norcal
I hear you. I'm tempted to put in one of those old school pits to work under ours when we get some dirt work done this Fall.
OnlyStihl
5:17 PM
PNW
I guess I'm in the mood to work on the Toyota. Just did the spark-plugs. 145K miles, no problems were being addressed. Took me about 2 hours. What a PITA. Easily saved me >$200, maybe even $250.
What blew me away was the condition of the original plugs. Gap is supposed to be 43 thousand (0.043). Severe wear on the electrode and the ground. The gap was over 70 thousand. Amazing the car even ran.
Yukon Stihl
4:17 PM
Great White North
Lifts are pretty cheap these days
I bought a 16000 lb one for my shop 26 years ago
Last year I had an interested buyer in my shop but they wanted the hoist left in place, which wasn’t part of my plan as I am not going without a hoist so it was going to be moved to my new shop.
I priced out the same hoist and it was cheaper now than when I bought mine.
Rotary 2 post hoist
RCBS
Redneck Savant Extraordinaire
7:17 PM
Ohio - The hilly part
I don't know who decided that car dealers need 1/4 square mile of concrete for a lot and 20 foot high ceilings on a 200,000sqft facility, but the added overhead doesn't help with sales prices or shop rates for the consumer. I ain't impressed with your fancy building... show me a good mechanic.
FergusonTO35
7:17 PM
Boonesborough, KY
I did a bunch of those on Toyota trucks and 4Runners when I was in the business. Usually, the customer had let it go on for so long that the oil had washed all the grease out of the wheel bearing and we had to replace that too. Good that you caught it in time, the bearing is not fun to replace and requires a big arbor press.
OnlyStihl
5:17 PM
PNW
I had to borrow a 24mm impact socket from a neighbor to get the differential fill plug off. Was rusted badly, but with a hand held impact driver I got the socket on real real tight, but still it would not budge. With my Air Impact Driver set at 1of3 it finally moved. Big Sigh of Relief!
I had a little less then a quart of 75w-90w gear oil on the shelf, and used it all. It still needs more. Unbelievable how things have developed and yet everything is fine. I ordered a new fill plug, even though the original isn't so bad when cleaned up. Ordered another Qt of Gear Oil, and will top it off and put that maintenance to rest.
I have had a version of this tool for over 40 years and still use it regularly.
OnlyStihl
5:17 PM
PNW
I got one of those recently. Don't know how I made it this far without one.
Back in the day, they were essential for removing Phillips head bolts from motorcycle engine covers. Without, stripped heads were very common and almost unavoidable. At 16, me and friends didn't know enough to replace with Allen head bolts.
Firewood Hoarder
Just a firewood hack
6:17 PM
Wisconsin
I distinctly remember needing one of those impact drivers to get the hardware out of an '81 KX125 case so I could rebuild it.... I didn't know any better, either.
I blame that bike for my 2 stroke addiction. Absolute dog until it came up on the pipe, and then it was less of a dog, but fun 🤣
