- 11:59 PM
- Jan 17, 2016
- Wv
#1 husky lover he bleeds orange.Who's Dall?
Husqvarna is his life.
Present day saw sure looks clean, they both run well.Some times it takes some time before you get to port a certain model again, so I was pretty stoked to get to do the same saw as one I haven't seen in quite a while, a MS361 Stihl. So here's the vidja's of them both cutting frozen pine, the major difference being the chains. The early vidja is with a chit bar and a Stihl square chain, the present vidja is with a nice bar and a chit round ground chain, the square was self feeding, the round is being pushed on, both are running a 7 pin. I really liked how this "new" build turned out.
Two years ago:
Present day:
My old 361 is over in Wisconson now, just not so far northwest as you are.
Ive got a ported 440 like that, all new bearings and seals, the jug was brand new when it went under the knife, nice runner for sure. Just realized the lower dog hole is stripped out this week, hope to fix it over winter. Suggestions on a best fix, or devcon and retap it?The "more used" looking one I rebuilt with all new goodies on the inside where it counts.
I like keenserts if you have enough meat there. No special tools required and it's a real solid fix.Ive got a ported 440 like that, all new bearings and seals, the jug was brand new when it went under the knife, nice runner for sure. Just realized the lower dog hole is stripped out this week, hope to fix it over winter. Suggestions on a best fix, or devcon and retap it?
Not bad, but I pulled it out by hand, I thought this was a husky problemIf so a helicoil will toughen it up if that's enough.
Sometimes a 6mm hole is better.
HLSUPPLY has inserts that you tap to 8mm that work.
A lot depends on how badly it's wallered out.
Not bad, but I pulled it out by hand, I thought this was a husky problem.
Not a fan of helicoils. I figured and industrial epoxy like devcon would be almost as good as the mag case for a hole like this. I wouldn't be opposed to opening it up a bit and going a size bigger though.
Tap to m6. Never seen a Helicoil hold up to the abuse and vibration.Not bad, but I pulled it out by hand, I thought this was a husky problem.
What happens when someone wants to put some big dogs on it cause they can't setup a chain or want to drop some bigger treesRed loctite.
I'll probably try the devcon, it's some nasty stuff, if it won't hold the next size up works for me.Tap to m6. Never seen a Helicoil hold up to the abuse and vibration.
DefinitelyRed loctite.
What happens when someone wants to put some big dogs on it cause they can't setup a chain or want to drop some bigger trees.
Maybe I need to swap everything over to a set of pretty cases.
I've had some bad experiences with helicoils, not ones I did either.
I’ve epoxied the bolt in place. It holds the bolt, but not tight. So eventually the hole wallers out. I’ve tried drilling and tapping the epoxy, and it strips before the bolt is tight. M6 just seems to be better when the original m5 wasn’t strong enough to stay tightWhat happens when someone wants to put some big dogs on it cause they can't setup a chain or want to drop some bigger trees.
