hseII
Heef
- 4:17 PM
- Dec 29, 2015
- West Georgia
Hooskies don't have this problem. Operators too busy looking for screws that fell out. LMAO [emoji23]
#NoHotStarts
You know the old grub screw vents worked just fine.....Tank vents aren’t designed to allow pressure to escape......you know that right?
I really wish they would put the little serations under the screw heads like Stihl screws haveHooskies don't have this problem. Operators too busy looking for screws that fell out. LMAO [emoji23]
Cuz ....yethLeprawookie,
Weren’t some of the pre-EPA vents designed to allow pressure correcting?
Sawhawgz, ruining the internet since 2012...
I do know that Jeremy, but the only thing I can figure is tank pressure was causing pressure at the carb and fuel was leaking from/through the gaskets in the carb. This was only happening when the saw was sitting unused and got even slightly warmer than ambient temp...e.g., sitting in sun, in my toolbox, or in my shop. Is there something else that could be causing this? I'm open to suggestions, it's just making a mess
Sorry guys, I overthink things a lot of the time. I came by it honestly, though. @longleaf knows my dad very well, lol.
Thanks for listening to my ramblings today
It's the EPA'S fault I'm sure , zero venting ...just like gas cans ...
My huskies leak bar oil all over ....gas ,not so much ...im.honest about it...lolDid you store any Huskys near it?
You know the old, “you lay down with dogs, you get flees” proverb.
Genuine Walbro and Zama Chinese carb kits. All surfaces were clean with no old gasket material. I don't believe its leaking from the H or L screws. After pressure testing the carb, I went back and tightened the s-word out of the screws and tested again with the mityvac. Much better than before.
I also made up a rather simple but effective tank vent for the 440 today that's essentially open to the atmosphere. I drilled a hole through a tapered rubber "cork" stopper and forced the stopper into the vent hole. Then used a small brass fitting to attach to a line that runs up under the top cover with a screw in the end of the line. Stihl used the same basic setup on a lot of older saws--a line with a screw in it. Except they used a "vent insert" 1120 358 8105.
Ran a tank thru it today (tank #20 since being hybridized) and it ran strong, no leaks from vent or carb. I ran saw in all positions. I fueled it up and will let it sit in the shop, where it should get plenty warm. We'll see how my redneck tank vent works.
The Husky wasn't laying around LOL. It was to busy cuttin.
Is it still good?The Husky wasn't laying around LOL. It was to busy cuttin.
