- 11:03 AM
- Mar 13, 2023
- Maryland, USA
Alright we're back in the saddle. I got a call from Doc yesterday morning. He had a grand idea to shave weight off this slug without weakening. He said to drop the bottom ring and cut the windows higher into the land. So with that goal in mind, I chucked up a new cs900evl unit, cut the top to @Ketchup 's recommended (and proper) squish of 0.022". I had nipped the skirt on the other one to time intake and block less port, so I just turned them both up to that height. Still sitting pretty at 80* intake. Put it on a healthy diet and it's a few grams lighter yet. Minus a ring, and plus an oem tapered pin, this is nothing but improved, and stronger.
This is the original echo slug, 2 rings, and lrb pin.
Improved Doc(tored) unit, 1 ring, oem pin. Over 7 grams lighter.
Tonight after work, it goes back in the hole, saw goes back together, and tommorow I'll run it and we'll see if the intake port is doing the trick!
