Stihl MS 440 Magnum for Steve
redline4
I'm huge in Japan
10:29 AM
Rosholt Wisconsin
This one has no decomp. He wants one too. I'm wondering if the 460 jig will bolt on to the 440 case. Before I dig in, I want to rattle around some options.
Get an Elasto-start handle and carry on.
I have that on my 044 and a regular old rope and handle on my 046. Vast difference in starting.
11:29 AM
Surprising. The 046 has the smart coil with timing retard on start. I’ve only seen the dummy coils on 044.
The 046 with an elasto and a decomp is a 2 finger starter.
11:29 AM
redline4
I'm huge in Japan
10:29 AM
Rosholt Wisconsin
The elasto on the 460, if it had one, was long gone by the time I acquired it.
I just haven't gotten around to putting one one. With it and the decomp, yeah, it will pull easier than the 044.
maulhead
9:29 AM
Home
8 screws you could swap the recoil from the 044 to the 460, and see if you like the 460 with a elasto starter more gooder.
Just a thought......
NateSaw
11:29 AM
Maryland, USA
It's a 12mm straight fun non-decomp... But, that hardly matters......
NateSaw
11:29 AM
Maryland, USA
.... Because we're going 440/460 hybrid with this one. Thank to @Canadian farm boy . I ran some he built at @Duane(Pa) gtg on the hill and I was SOLD!
NateSaw
11:29 AM
Maryland, USA
@Glock37 is such a wealth of info... He's given me a parts list with numbers, and will be powder coating the mag parts. This will have the kolben oem non d chamber jug and slug. Brand new. It's getting new oem bearings, seals, boot, hoses, av mounts. New am covers. Wcs dogs, East coast profile. I'll again do the max-Flo foam with a 461 air horn and carb studs.... This one's gonna take a while.
Canadian farm boy
“Normal” people scare me.
11:29 AM
Ontario, Canada
hardest part of a hybrid build is fitting the 046 cylinder to the 044 cases. I use the 044 gasket as a template and use a sharpie to mark the bolt holes and edges of the cylinder so I know how much and where to file/grind material.
You may need to grind a little off the outside of the FW side transfer tunnel to clear the FW.
You’ll also need to grind away a couple of the lower cooling fins.
Canadian farm boy
11:29 AM
Ontario, Canada
Lots of pics of a 044 hybrid build in this thread.
NateSaw
11:29 AM
Maryland, USA
@Glock37 mentioned skimming the back of the flywheel on the lathe. I remember you telling me how you did the gasket match. And the chain file working well. The transfers on this new cylinder are art. They have a pretty hard slant towards the intake. And they are the flatest I've seen yet, other than Doc's in my 026.
Canadian farm boy
11:29 AM
Ontario, Canada
I meant bend my ear about the headache 😂. Yesterday morning I was dragging ass until I got that first cup in me.
I’m good as long as I get a caffeine fix at least once every 8-10 hours. Thanks again for the coffee hook up last weekend.
Canadian farm boy
11:29 AM
Ontario, Canada
You can cut some material off the FW or the transfer tunnel. Whichever is easiest for you. I prefer taking it off the FW
