dmb2613
- 12:57 PM
- May 13, 2018
- Randolph Virginia
I may be wrong, but I feel messing with the timming on a M Tronic saw will do you no good, A broken key way in a flywheel is not a big deal , just get the flywheel good and clean along with the crank and tighten it down, It will not move . mark it to make sure it doesnt move when you tighten it up.
You may need to put a solenoid in it , that may take care of the resetting issue, then it will most likely rev up higher
