Stihl 1125 (034/034S/036/360) Cylinder/Saw ID
Stihlsmoking
City Hillbilly
6:52 AM
Cincy
@drf256. Al I'm working on a couple 034's and have both standard 46mm one Mayle and one KS the mahle is open port the KS is closed or bridged ? Is one better then the other ? Thanks
Will get pics later.
Wonkydonkey
Plastic member
11:52 AM
Sussex, UK.
I would have said the mahle will be a better runner, due to it being fully open transfur. A bit like the ms200. But it would still depend on timing numbers.
Pop a timing wheel on and post the numbers, someone will say what's the better to use stock or ported.
Cheers
Stihlsmoking
City Hillbilly
6:52 AM
Cincy
Cheers
Don't have a degree wheel yet ? And when I do I'm gonna have questions. Lol
Think I'm gonna try mahle on side adjust made in Germany case ?
I don't know if someone swapped cases along time ago or not serial
#114985302. ?
Adamski
Plebus Splederns
11:52 AM
Essex, UK
I think most people prefer closed port, but I could be wrong. All the pro saws are closed port, homeowner saws are open. That is my perspective.
I felt this way until recently.. .Would you class an ms200t, an early 034 or a 365 as homeowner? I have or have had all 3 and I feel the 034 has some serious umph as a 56cc open and the Jonny-red 2065 (365) is open port and may be slower revving than the 372xp but as of yet is very hard to bog down and is a torque piggy. The 034's and 365's are the same build as the closed counterparts so all I can see them loosing out on is chain speed. But for ham fisted users like me they gain the low down grunt.. IMO
Adamski
Plebus Splederns
11:52 AM
Essex, UK
Cracker Boy
Fl cracker
6:52 AM
Florida
Some of the 034 cases with front tension didnt have adjustable oiler either nor the hole in bottom of case for the oiler.i have had and built a nice 034 side tension with a ks closed port
