Stihl 1125 (034/034S/036/360) Cylinder/Saw ID
9:32 PM
I think you still might be able to get a metal mesh air filter for the 034.
10/80
11:32 AM
Part number for the complete mesh filter... 1125 120 1610.
I don't see a part number for the complete fleece / flock type, only numbers for the two halves.
1125 120 1615 & 1125 120 1620.
Lightning Performance
9:32 PM
East of Philly
I was about to make this flocked OEM filter into a custom foam panel. My original has the face flocking blown off. The inside and back panel are near mint. Too nice to wreck it. Cut two tanks of firewood and did chunk downs with it oily and got a bit through the filters three small holes. Has three small ones that can be repaired.
I have a complete running 360 Pro here to mix and match parts with plus what apparently is an 034S cylinder not an 036. My new to me saw and the extra jug I bought are 034. 036/360 plastics are available new AM so any combination is here already for the shell game :)
This saw cleaned up really nice and needs nothing. It's ready to eat and likes the 325 18" 8p for small stuff.
9:32 PM
East of Philly
Anyone have or direct me to air filter for 034?
Not AV, not super, not pro, I think its a 1991.
Local dealer no help and the pine tar is killing me.
See here
5155
9:32 PM
pa
Between these part #s, what Dr said about AF cover difference, and comparing mine with pics I got it ordered. THanx.
The existing AF has no number, AM?
I studied that master control some more.
The inside of AF were the choke plate swings had burs. I shaved them with sharp razor knife.
Choke linkage when held inward worked better than outward so I opened that U bend a little.
I'll be 1st to know if this helped.
Gotta love these oldies lol.
Bucking the large pine "almost" done.
12 tanks in.
After the filter arrives I'm going to adjust carb.
With some luck (help) I might get a vid for critique because OPE forum is great for this.
Carb rich now, but just had new rings.
9:32 PM
East of Philly
12 tanks in.
Lean it down a bit if your ten tanks into new rings. I start tuning after the first tank. Run regular oil or full synthetic will take a good ten to twenty tanks tuned up to come around. Moronics break in faster they say, idk about that but they never run fat in the cut and don't blubber much.
9:32 PM
East of Philly
The choke on my 034 needed adjusting at the rod but seems fine now.
president
6:32 PM
peachland BC Canada
Do you know of a tilly, carb for one.Both of my c3 zamas
are problematic.Someone suggested that a sonic cleaner may damage
the check valves ,and the other one wont stay adjusted
I put new seals into it also ?
markds2
1:32 PM
Nelson, New Zealand
I just scored this today, haven't got the saw yet but I'd thought I'd post it here so I can find the thread again. Cylinder pics to come...
9:32 PM
Randy, did you move? I seem to remember a different town ... or did they just add a new PO like where I grew up.
