Stihl 066 Red Light
Definitive Dave
Piss Rev Mafia Member
3:58 AM
Central Ohio
35 should have a larger main jet than the 67 I believe
Not sure if either has a removable jet though
Brewz
6:58 PM
Hunter Valley - Australia
WJ35 top
WJ67 bottom
Jet sizes look similar but the 67 has a removable jet.
I can't see any big advantage in the removable jet carb on this saw as it will never be a ported compression monster.
I re-measured the Venturi and they are the same.
I am thinking I will stick with the 35 on the saw.
I can't see it holding the saw back
Brewz
6:58 PM
Ok
So this thread is not meant to be about just my saw.
Who else has a red light?
Pictures, stories, information, carbs, port timing numbers, video's....... get em up!
jmssaws
Banneded
2:58 AM
I prefer the wj35 over the other carbs, the removable jet is not a priority of mine.
Glock37
3:58 AM
Monroeville Pa
How does a wj 67 without limiter caps compare to the wj 69 with limiter caps. From my findings the 67 was before the 69
jmssaws
Banneded
2:58 AM
It's a good carb also,I've not had any problems from any of them.
I do like the adjustment screws that are the long old school ones.
Brewz
6:58 PM
I have rebuilt the WJ-35 and fitted it to the saw.
I figure if there is not going to be any real difference, I would prefer to keep all original parts that came with the saw, on the saw.
I set the screws to 1 1/4 turns each and it kicked up and idled no problems at all, but you really notice the difference the elasto-start cords make.
If your not super confident and forceful with the cord from TDC, it punishes you for having chicken wings!
I am in love with it!
If I get a chance to run it over the Easter long weekend, I will try and get a video of it in action
Brewz
6:58 PM
My flywheel cover has seen better days.
The mounting holes are enlarged, it is broken and flogged out where the chain brake attaches and the STIHL Made in Germany badge has a hole punched in it.
I would LOVE it if someone out there had an original red light flywheel cover in good "not broken" condition that whey would be happy to part with.
Deets066
AKA Deetsey
3:58 AM
Hard to find those in nice shape, your in the right place though
Brewz
6:58 PM
I have a wire wrapped around the ignition lead.
It works fairly well but what tach would you recommend?
Deets066
AKA Deetsey
3:58 AM
I haven't tried that one with the wire, maybe that does help a little.
I have a Hard Line but haven't tried it yet. I'm behind on my saw projects
Brewz
6:58 PM
Had a play with the red light today :banana:
Went great, no issues, but I dont think the red light works 100% correctly. It was hard to tell in bright sunlight.
Anyway, It maxes out at 13500 rpm and I ended up bringing the tune back to about 12400 or so, but it was boggy in the cut when I really lent on it. Could have been the 8 pin in filthy hard timber too.
It held about 9200 RPM in the cut
I had a bit more of a fiddle with the L and H to try and find a sweet spot and I got it better but it still has more.
Here it is with its first basic tune.
20" bar 3/8 full chisel chain and an 8 pin sprocket.
Timber is dry and really hard. No pine to make it look faster here.
I am looking forward to a bit of time running the saw, getting to know it and touching up the tune as I go.
It is an absolute tank of a saw and is fast becoming my favorite.
I am going back to a 7 pin sprocket. I dont like the high speed chain in the hard timber. I feel I get a better cut with a 7 pin.
I plan to do some tests on this.
Next is to get the timing numbers and perhaps a touch of mild machine work to improve the numbers if needed.
Deets066
AKA Deetsey
3:58 AM
Looks pretty good from here.
How did the tach work for ya?
Brewz
6:58 PM
Brewz
6:58 PM
Ha ha
Old mate got back to me saying no to my offer of $200 because they were in perfect working order???
I replied saying I had not seen a 25 year old used chainsaw that was "perfect"
Poor choice of words from him I think
