066 coil question
C4rest
OPE Member
4:33 PM
Travelers Rest SC
Hello all, I recently got an 066 red light that the seller said was all original and that it ran. He showed me it ran but the light didn’t light up. I still traded for it but when I got home I found it did not have the original coil on it. It also has a flywheel with two key ways marked 1122 400 1209. I have researched and researched and to be honest am still confused why it has 2 timing key slots. I also would like to know if I did find an original coil would I be able to use this flywheel and it run properly? Maybe just move the flywheel over into the other slot. My other problem is obviously finding the original coil as I cannot find one. This saw is in immaculate shape for its age, very little use. I would really like to get it back original. Thank you all for your time!
jacob j.
Only the weird
1:33 PM
Coastal Oregon
If it has the two keyways on the flywheel, you can use the 0000 400 1300 universal coil with slot "X" I believe (if the slots are marked "B" and "X" or "P" and "X").
The 1122 400 1209 number is the part number for the flywheel. Part number for the original Red-Light coil is 1122 400 1307. Original working red-light coils are getting hard to come by - They have a habit of "browning out" or failing completely.
jacob j.
Only the weird
1:33 PM
Coastal Oregon
Here's a thread on Arboristsite with a lot more info:
C4rest
OPE Member
4:33 PM
Travelers Rest SC
Thanks for your help. My flywheel does not have those letter markings, it just says “warning.” I will look into that forum again thanks!
C4rest
OPE Member
4:33 PM
Travelers Rest SC
If anyone has one of the original coils I would love to buy it from them. I’ve always wanted to see the light light up 😂
lehman live edge slab
Live Action
3:33 PM
Mn
Good luck and if you find one that works odds are it wouldn’t reach proper max rpm anymore.
