Stihl 046
5:59 PM
In the pic showing the broken piston, is that a crack in the case in the lower left of the pic??? That could have caused this!
I thought the cylinder would be good! Unless they ingest hard metal (not piston aluminum) they generally hold up.
5:59 PM
Maybe it is just dirt, but on page 3, frame 48 lower left of pic (about 1/4 over), it looks like a crack in the case.
Canadian farm boy
“Normal” people scare me.
5:59 PM
Ontario, Canada
what's the difference in the coils ? Is one better than the other?
From what I've heard the 1309 coil is supposed to be "the best". It apparently has a more aggressive timing curve. I can't say for 100%. Personally I haven't found much difference between the coils.
I also heard that the 1309 coil only came on the first year 046 saws.
This is all just stuff I've heard. Not sure how true it is. I was just curious which coil you had because you also have a D cylinder which was also supposed to only be on the first year 046.
