squish bands
Redfin
Meh...
1:10 PM
Central Pa
Mixture will indeed get trapped in the quiet if it's designed poorly. It's actually a pretty big spare of unburnt HC emmissions in four cycles as the mixture in that area often doesn't combust.
Other than unburnt hc, are there any other side effects to "trapped" charge?
bwalker
1:10 PM
Montana
In a two cycle it's the source/ cause of detonation. Though this isn't an issue in saws as they have fairly low compression ratios and the motors are not typically loaded very hard. Milling would be the exception.
Hedgerow
12:10 PM
When milling, I've not noticed a harder "Load", per say, being put on the 9010 than any other application.
I do, however know the length of run at full throttle is way the hell longer than dropping trees, and no break to idle.
So I'd think heat dissipation would be the largest concern of a fellow running a chainsaw mill.
Seems more fuel mix flowing into the crank case would be even more important than a richer oil to gas ratio.
junkman
Crush it
10:10 AM
pacific northwest
With free flowing exhaust i have milled several hours on end without overheating ,just keep the chain sharp so the powerhead is not overworked .
Hedgerow
12:10 PM
better view of the flat squish band and torrodial chamber
Crude measuring from the screen puts the cross sectional area of this band somewhere between 60 and 70% of total area?
Don't have the actual measurements, but just a visual of proportions.
bwalker
1:10 PM
Montana
Both are very important when milling. As you noted the time at full throttle is much longer thus the migration time is very short. In addition milling does load the motor more than bucking and that's easy to prove based on the fuel requirements.
Hedgerow
12:10 PM
Define "load". We may have a gap in terminology. A full throttle cut dropping a saw from 14,000 rpm to 10,000 rpm whether bucking a large log, or laying on it's side milling a 20" slab would seem the same from a layman's perspective. Or does length of duration at said full throttle somehow add to "load"?
1:10 PM
Depending on chain cross cutting I may see 1k more rpm than milling. I touched one up the other day and had to hold the saw back the first cut, second cut was self feeding on its own, and third was a little push halfway through. First cut was 9k rpms or so and it went up 500 by the end of each cut. I need to get a hardline tach so I can watch it easier. 6.5 minutes without letting off the trigger is a long time.
tree monkey
12:10 PM
wi
he's talking about residual oil in the crank case.
don't know what that has to do with squish bands
