- 6:19 PM
- Dec 3, 2015
- Banner Springs Tennessee
lol I was hoping for a decent reaction![]()
I like turtles.
What kind of turtle? Turtle sauce piquant? Or a turtle head poking out?
I like that saying...your Dad is a wise man. Now let the eternal oil wars go on. The Lucas I use has already been rated as garbage despite the certification testing it has past. I always spit in my the oil before I mix it in so it is not true Lucas.You don't need 2-stroke or any other oil in Your saws fuel if You kill the engine before friction occurs.
That is how my dad made it to his current age, "You stop whatever You are doing five minutes before You start sweating, that way You don't get tired!"
I see you have the 193T. I have a 192C rear handle...had to do a muffler mod cause not enough power to push smoke out. Fuel oil hmmm.Fuel oil.
I like to roll coal outa my mooflah.
Agree 100%!I’ve noticed more differences from using different quality or octane gas. That definitely has a effect. Fresher is always better.
This surprises me ..................... NOT !!!The Lucas I use
Why would the oil cause the big end bearing damage but no scoring or cylinder damage?I've seen exactly one failure that I was 100% sure was oil related.
Had a customer use a ported 088 for milling while running Amsoil Saber at 80:1. It melted the big end connecting rod bearing, and locked up. No scoring, no cylinder damage.
Aside from that, I've seen no true oil related failures. Castor oil is dirty in a saw from what I've seen, and some oils make drool from the exhaust. But a proper tune and extended run times could probably clear up most of that.
In other words, use the oil you like.
Yes, as long as it's not mixed 80:1....<snip>...use the oil you like.
Over the year's I've Customers have brought me 6 or 7
True oil failures
All had excessive carbon and stuck rings
All from Stihl ultra
I have no idea on age or mix ratio or ethanol free or not
Don't recall any orange bottle issues.
Does anyone have the test results?Long story, but if you want the straight poop a member here did extensive testing to destruction and found amsoil dominator to be the best. Red armor protects well too but may hurt power. Supertech synthetic is probably the best value.
