Simington / Silvey Square Chain Grinders Tips/Tricks/Secrets
MG2186
3:14 AM
Summer,IA
I just got my 451C. Just starting the learning process
MG2186
3:14 AM
Summer,IA
Nice, how you like it?
I think it's over priced for what it is but what isn't these days. I had to shim the motor to square it up but other than that I like it. It's going to take me some practice I know. I'm just trying to make a nice uniform cutting chain at the moment before I even attempt to adapting different angles and what not
Duane(Pa)
It's the chain...
4:14 AM
Centre County
Is the grinder new? Just wondering if you had to shim it "out of the box"
MG2186
3:14 AM
Summer,IA
Can someone give me some pointers on when converting round to square, I seemed to be taking a lot off the cutter to get it right. Forgive me if it's been mentioned I've only made it to page 11 so far
Duane(Pa)
It's the chain...
4:14 AM
Centre County
It's hell on grinding wheels too. I got a bunch converted with a salmon wheel, then got a blue wheel to touch them up.
Duane(Pa)
It's the chain...
4:14 AM
Centre County
Just get enough to have .050" side plate. Then use and sharpen again. No use killing 20-30% of the tooth to get a full sideplate
I have a chain that's somewhere in between square and round, boy does it look wicked. Haven't tried it yet but I have a feeling it will saw wood!
MG2186
3:14 AM
Summer,IA
So when it starts resembling a square tooth, quit grinding? You got any pictures Mike
4:14 AM
I don't have pics, but 4 well placed file strokes will be close to what he's talking about. I filed a couple inside out while converting. Wasn't as hard on files. Seemed to work ok
Hedgerow
3:14 AM
Cutter looks good.
May want to move the intersecting line down just a tick to be in the lower part of the working corner.
That'll engage the wood a little better.
And like Mike said, you don't need a full side plate square to cut well, just enough to sever the thickness of a chip.
Race chain = soft wood = thicker chips = more side plate.
Work chain don't need as much.
